Question about Zanussi FC1200W Front Load Washer
How to change the brushes on a zanussi 1200 washing machine
    Sergeant:
  • 231 Answers
Very easy when you have the motor out and on and table all washing machines have a different size and shape units so if I was you go on youtube put your make and what you want to do then it will show you for your make but all the same principle
Posted on Dec 16, 2017
murdozzz2
  • 75 Answers
SOURCE: RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Posted on Dec 14, 2007
kjmac
  • 97 Answers
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Posted on Jul 28, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
  • 1294 Answers
SOURCE: fitting of door seal on zanussi electrolux washing
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Posted on Mar 12, 2009
E40 fault on zanussi washing machine is it worth repairing or to buy a new one 8-9 yrs old ?
A Zanussi E40 error usually indicates "Door open.Check interlock and associated wiring check door latch,check module and connections." However, what most people don't know is that most manufacturers route the poser to the door interlock through the same curcuit that powers up the carbon brushes on the motor. So if your motor brushes are worn down, the door won't lock. Your machine is about the right age for its brushes to be worn out, so I would check this out first. Motor brushes are cheap, easily available on Ebay and fairly easy to fit. Take the current brushes out, if they are less that three quarters of a centimeter long, changing them is a highly likely fix for your problem
Oct 31, 2015 | Zanussi Washing Machines
Zanussi 1200 aquacycle fx1265w
Either it not getting water, or the motor brushes are worn out.
Sam
Jun 21, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi progress 1200 won't take softener into
Hi there
Now I am urprised. There must be three dispensers in your Zanussi as in my Candy.
One is for the main wash another for prewash and the third one for
the softner.
Look in the manual.
Kolbrun
Feb 26, 2012 | Zanussi Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
hiya
hope this helps
Jul 08, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FC1200W Front Load Washer Logo
139 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
