Question about Health & Beauty
Replacement charger need to buy a new electric charger for a nikki clarke hair trimmer.ncm16.have looked on the net but cant find one.can u help please?
  • 4gus3rut Jan 31, 2009
    I bought a seiko shaver ES1950 in tokyo many years ago. I need a new electric charger for it (12V ..).
    Someone would mind to help me for finding it ?
    Many thanks.
SOURCE: HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Posted on Jul 27, 2009
brector3
  • 1614 Answers
SOURCE: Hair trimmer does not work - no visible reason!
If the trimmer is actually broken, you can not repair it. More likely, it is just jammed or has a buildup of hair particles and skin oils causing it to be locked up.
Take a very shallow dish of rubing alcohol and dip JUST THE TEETH of the trimmer in it. Then turn on the shaver and attempt to use the trimmer. Repeat this process several times. The alcohol may help remove any build up that is present. If it still will not work, you may have to help the blades out a bit by manually sliding the moveable blade back and forth once or twice. You can advance the moveable blade with the tip of a jewelers screwdriver or similar object. Once you've advanced the blade, do the bit with the alcohol again to be sure any remaining residue is rinsed away.
Posted on Feb 22, 2010
brector3
  • 1614 Answers
SOURCE: require replacement charger pc-0310-mvd(bs) for
You will find a replacement charger for Remington MB-40 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-charging-cord-for-select-mb-models-p-551.html
Posted on Dec 05, 2010
brector3
  • 1614 Answers
SOURCE: I'm looking for a charger
You will find this charger for MB-300 at shaveroutlet.com. See link below
Posted on Jan 06, 2011
  • 1833 Answers
SOURCE: Remington body hair trimmer bought
If you want a replacement then you should have to contact " http://www.remingtonproducts.com/". Hope this will help you.
Posted on May 27, 2011
How do I know what needs to be replaced?
Check the charger with a voltmeter to be sure it's working. If not replace it. If it is, replace the battery.
However, be aware of pricing. Sometimes it's better to just replace the whole system.
Aug 31, 2016 | Remington BHT2000 Hair Trimmer
Remington hc 600
You will find a replacement charger for model HC-600 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/remington/remington-hc-600-charging-cord.html
Dec 30, 2013 | Remington HC-600 Hair Trimmer
Philips norelco G370 charger not working..
The prob is simple, the imported ones have adapters made for 110 Volts whereas in India the standard is 240, so ur adapter has simply 'shot out'. I faced the same prob and if u know little electrical stuff, fixing it is a piece of cake. first ull have to buy one of those adapters which have an adjustable output voltage, i found only one online on rediff.
http://shopping.rediff.com/product/all-in-1-power-adaptor/10300314
but i bought mine from kerala for 90bucks. then all u hav to do is cut the pins of both ur new and old adapter, and join the old original pin to ur new adapter, seal the joint with tape, adjust the voltage on the adapter to 1.5V and ur good to go :D
I did this just today and the trimmer is back-and-running!. XD
Hope it helps since this will settle it for 200 bucks flat and since a new original philips charger costs over 1k... :
Jan 28, 2013 | Philips G370 Hair Trimmer
Charger problem
Jul 03, 2012 | Philips G370 Hair Trimmer
I am looking for a replacement power cord for remington R7130, where can i get one
remington pa-400 12v adapter power cord for electric shaver remington r7130 charger replacement parts.
Input: 100-240 VAC 50-60 HZ, Output 12VDC 400 MA
remington r7130 charger power cord
May 22, 2012 | Remington R7130 Hair Trimmer
Iam needing to purchase another on!
Thanks for using Fixya.
You can buy Emjoi Petite Facial Two-in-one Facial Care Tool AP-91 Hair from this link.
Good luck.Rating the solution is highly appreciated.
Mar 13, 2010 | Emjoi Petite Facial Two-in-one Facial Care...
Replacement Charger
Sorry have'nt got the awnser, but have got the same problem. If you did get the details of a supplier i would be very greatful if you could pass them on to me. I've looked everywhere and need to cut my hair
many thanks
smurf.7@hotmail.co.uk
Jul 30, 2007 | Remington HC-600 Hair Trimmer
Health & Beauty Logo
172 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
