Question about Frigidaire Affinity ATF6000F Front Load Washer
Door lock won't lock onfridgidaire wasningmachine
Door lock solenoid is not working
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Posted on Nov 18, 2012
95 Camry Electric Door Locks Won't Work
It could still be the relay, if the solenoid is working but the contacts are faulty. There are also several other places in the circuit which could cause this. Follow the diagnostics from p90 on, here
http://www.turboninjas.com/camry/be.pdf
Jun 25, 2012 | 1995 Toyota Camry
Does any one know why the drivers door won't lock
The power door lock solenoid/mechanism may be bad. A bad solenoid would not keep the door from being locked with the key.
Sep 16, 2011 | 2011 Ford Fiesta
I have an LG WM2701H. It's about 2 years old. I did one load of laundry this morning, everything was fine. I started the second load, walked away and after a few minutes noticed that the washing...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 23, 2011 | LG Washing Machines
My passengers side sliding door won't unlock. I was able to get the inside trim off the door and expose the inner workings but was unable to unlock the door manually. As i was trying to put enough...
Look at the other door and look on the front edge to see where the child safety lock switch and see if that is the problem with the other door. That has happened with mine several times. Someone will play with it leaving it on so it can't be opened.
Jul 20, 2011 | 2002 Chrysler Town & Country
The DL error just came on. Is there something specific we need to do to fix this? It has been working fine, but then all the sudden the error started. Upon initial machine start, it works fine, but then if...
Presumably it is still under guarantee/warantee? You should contact the washer's service department before doing anything else as 'DL' does stand for Door Lock (error).
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor needing an engineer's attention ;-0(
John C
Jul 16, 2011 | LG WM2277H Front Load Washer
Aol.comLE error code comes on and machine won't operate
'le' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
John C
Jun 14, 2011 | LG WM2487H Front Load Washer
First problem started when the passenger door didn't open from outside. Now when you lock the car, the passenger door won't lock.
Sounds like the locking mechanism in the passenger door may need lubrication. You could also have a wiring issue and/or the actuator solenoid on that door could be bad. I'm assuming you are using the keyless locking fob. What happens when you push the door locking button on the driver's side door or the locking button on the passenger door itself? If these work as they should and with not hesitation then you likely have some other problem in the locking system.
Jun 11, 2011 | Volkswagen Golf Cars & Trucks
My affinity front load washing machine stopped mid-cycle. The door won't lock so it won't run and it has water sitting in it. Is there anything we can try before calling a repair man?
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Sorry but both require a service engineer's attention I suggest ;-0(
John C
Jun 06, 2011 | Frigidaire ATF6000ES Front Load Washer
2006 chev.colora the door lock on the front right side won`t work
Common for the door lock solenoid to go bad and your going to need to replace it. You may hear it clicking but it's to weak for it to lock and unlock the door.
Thank you for using fixya and good luck
Apr 26, 2010 | 2006 Chevrolet Colorado
Frigidaire Affinity ATF6000F Front Load Washer Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
