Question about Dell Inspiron 560 Desktop Computer (Intel Core 2 Quad Q8300 1000GB6GB) (DDPDAE431)
Connect dual monitors
I have one monitor set up in the normal way. Now I want to set up dual monitors. my video card is intel g45/g43 express chipset, which I read has 2 digital displays via DVI, HDMI and display outputs. But I don't know what that means exactly. My second monitor does not have an HDMI port.., but has a port with 24 square holes and a slot, and another with 15 pinholes, plus various tv type inputs. My computer has an available hdmi output and a usb output.but no second monitor port.
  • 70 Answers
The port with 15 holes is a VGA connector and most monitors have a connection for those it's a blue connector. The other you describe sounds like a DVI connector. Most new monitors have that as well and it's a white connector.
connect dual monitors - 11750867-tewsfb12kpevcqwroz5uwqx5-2-0.jpg Once you have both monitors hooked up and turned on, they should automatically come on and show your Windows desktop. You may have to tweak the resolutions if the monitors are different. That can be done in the resolutions settings : Control Panel\Display\Screen Resolution
This video, starting around the 2 minute mark, gives a good overview of those settings and what they do.
How to Windows 7 Multiple Monitor Setup
One thing he mentions that is important is that the monitors are set to the right inputs or source. Look for a button, usually on the right or bottom of the monitor, that says "source" or "input" or has a symbol of an arrow pointing at into a screen - it looks like #2 in this photo:
http://en.community.dell.com/resized-image/__size/550x0/__key/communityserver-discussions-components-files/3529/6354.monitor-settings.JPG
The monitor connected with the blue VGA connector usually says "VGA" or "Analog". The monitor with the white DVI connector usually says "DVI" or "Digital".
Posted on Feb 16, 2015
5 Suggested Answers
virusi
  • 95 Answers
SOURCE: how to connect 3 LCD monitors to a computer
Some cards can send 2 outputs that is split by the cable, which is connected to 2 monitors. Generally speaking though, most just split the image up
If you're not sure if your output supports multiple monitors off one output, it's almost certain it doesn't.
There is USB 2.0 to DVI, HDMI and VGA Multi-Display Adapter
resolutions of up to 1600 x 1200 Allows for effortless multitasking
Posted on Jan 05, 2010
Testimonial: "Good job! This will give me what I needed to connect my three monitors."
vanherringto
  • 1738 Answers
SOURCE: I have a dell dimension 8400. The graphics card
You may have left out a couple of steps.
Now, you need to configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab.
The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate.
If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
Now, again, reboot your PC to apply the changes.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Posted on Feb 03, 2010
stormblade00
  • 161 Answers
SOURCE: Connecting HDTV to computer
maybe you have installed the wrong driver..
if your device manager says bunch of yeloow question mark it means you have hardwares that are not working or not yet installed..
try to download your installer here...
click here
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=DIM_PNT_P4_8400
Posted on Feb 11, 2010
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
Posted on Apr 18, 2011
Appears to have a network connection drop out
One way of fixing it is by getting a netword card if u you are pretty sure dat the problem is with you mobo LAN port... The NIC/LAN card is very cheap .....
Dec 27, 2013 | MSI FM2-A85XA-G43 Desktop Motherboard -...
Monitor image became offset to the right. How to fix this?
Have you tried telling the computer that you want a single display and not dual?
Dec 19, 2013 | ASUS VW192S Monitor
New graphics card problems with my Presario SR5350F...
Make sure you plug in any auxiliary power cables are are required for the video card.
Is the card used. Has it ever shown signs of life?
Go into windows via integrated graphics and install the latest drivers.
After that I would go into your bios with integrated graphics and turn off intergrated graphics. Look around if there's like a setting that's like switch to PCIx graphics or something. After the restart try to use your monitor though your video card.
Apr 26, 2010 | HP Compaq Presario SR5350F Desktop PC...
Toshiba Satellite L305-S5919 Dual Monitor Help!!
Make sure the second monitor is actually plugged in and switched on when you make the switch.
Mar 21, 2010 | Computers & Internet
INstalled video card to D945 Intel board, and now the onboard video does not work. I wish to run 2 monitors with same input.
Unfortunately most basic motherboard chipsets do not support multiple monitor setups.
They are designed to become inactive when you connect a slot based video card.
to use 2 monitors you would need to connect them both to the card in the slot if it supports dual monitors.
Mar 03, 2010 | Computers & Internet
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
Dual display using the Intel G33/G31 Express
You need to get a graphics card that has dual video outputs that connects to separate monitors.
Getting a second graphics card won't work because they cannot work together.
Apr 27, 2009 | HP Computers & Internet
Where do i get the driver for a G45+MDHA 16D/OE6 Card?
Hi.
Download this
http://rapidshare.com/files/149632922/Driver_Scanner.rar
And 90% of your driver problems will be gone.
Keep me posted if you have further problem's.
Regard's
Faraz
Oct 01, 2008 | Matrox D7518A, G45+MDHA16D/OE6, 5065-4263,...
Monitor will not turn on after booting computer
if you have onboard video try a video card that fits in PCI or AGP slot or try a different video card in place of the one you use
with everything else seeming to be correct this seems like the only thing you have not done
Aug 03, 2008 | Intel Motherboard
Dual Monitors
This is a rather cheap one : MSI NX7600GS 256 MB Video Card
You can get it from Superwarehouse online at:
http://www.superwarehouse.com/MSI_NX7600GS_256_MB_Video_Card/NX7600GS-T2D256EH/p/1494596
Thanks,
Lolita
Apr 09, 2008 | HP Compaq dc5100 PC Desktop
Dell Inspiron 560 Desktop Computer (Intel Core 2 Quad Q8300 1000GB6GB) (DDPDAE431) Logo
1,000 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
