Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Convergence?? Recently the convergence on my sony went out, i was told by many how to replace it, i did with the right parts and correctly, it did not fix the problem what else could be wrong
Did you check the voltage for the convergence chip? if the chip was out, there is a posibility that the fuse has burned.
Posted on Oct 30, 2008
I have a Sony KP-57WS510 and am having problems converging. The red works fine however the blue cross on the outside colums of the convergence pattern is off to the left. I am unable to move these blue...
The tv convergence board it is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.U have all the tools and also can do soldering ICS works?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a complete convergence kit parts for ur tv model and repair it ur self.Or the tv shop,will cost u like $300-350 for parts and labors.
Apr 23, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Suddenly a curved line appeared in the upper left and lower right corner ....and words like "muting" and lower right words are doubled with a red virtual image....the main picture in the center is pretty...
Convergence problem---set uses two of the STK-392-560 convergence chips.
Both will have to be replaced and set adjusted with remote.
Total parts cost on EBAY under 25 dollars.
I can tell you what is involved.
see attached photo of typical convergence problem and typical convergence chip.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 03, 2010 | Sony KP-51WS500 51" Rear Projection...
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
Aug 10, 2010 | Sony KP-51HW40 51" Rear Projection...
Flash focus,convergence not adjusting pic quality currently have green to the left and red to the right cant adjust into alignment
Thats a convergence Failure. You can get the Sony type 1 convergence repair kit which is the correct kit for your model at www.tvrepairworld.com the kit contains the replacement parts and the CD with instructions for the repair.
Jul 18, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Edge convergence
Installing the Sony type 1 convergence repair kit from www.tvrepairworld.com should solve that issue. The kit contains the parts and the CD with instructions for the repair.
Jul 05, 2010 | Sony KP-65WS500 65" Rear Projection...
Red color is out of adjustment
The convergence circuit on these sets uses a digital correction signal sent through amplifiers (also known as convergence ICs) to electronically correct the convergence. If you can adjust the convergence with the remote and everything moves as it should then it is likely not the convergence ICs at fault. It is likely the digital convergence unit (DCU) that is not storing your setting. If you find one of the colors won't adjust or move properly to your satisfaction then it is likely one of the convergence ICs and possibly some resistors as well that need changing.
This is not really a DIY project.
May 23, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-53XBR45 convergence
Hey, found the problem. Your Convergence IC chip went bad. Buy one at Bluestar International Components (bluestar-online.com) - order part number STK392-010 for 6.99. I've read that there are two in the system and replacing them both at same time is a good idea...so, order 2. Now, if you are handy, it will require you to open the back of the TV and solder out the old chip and replace with new. If not, then you might as well call a TV repair person and have them fix. However, every place I've called works on a minimum fee for "large screen TVs" - the cheapest I could find in Atlanta was $399 minimum service fee. So, I'm going to risk the home sodering job .... it's a 10 year old TV and as good as it's been to me, if I screw it up, I feel I've gotten my money out of it. Good luck with your repair. My parts are on order.
Oct 15, 2008 | Sony KP-53XBR45 53" Rear Projection...
Sony kp-61v45 Blue Convergence off by 2 inches
you need to replace the convergence board its around 80 dollars
Aug 17, 2008 | Sony KP-61V45 61" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Television powers up then shuts off Kp-53v35
You likely have an open fuse caused by bad convergence ouptut ic's type #STK392-560 sony part #8-749-014-67. There are 2 in the set and i recommend replacing both at the same time.
Dec 17, 2007 | Sony KP-53V35 53" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
