Question about Panasonic DMR-ES40V DVD-Video Recorder
DVD door won't open
  • 1 more comment
  • Zelio Picanso Feb 19, 2012
    Is there a dvd in the device?Also, how old have you had this for?
  • MP Nelson
    MP Nelson Feb 19, 2012
    The display says there is no disk inside; since the door won't open, I can't confirm this. The unit is 6 years olc this month.
  • MP Nelson
    MP Nelson Feb 20, 2012
    Removed the DVD drive from the unit, and then the top from the drive. No DVD inside. Still couldn't open front door. On the bottom of the unit, I found a bar that slides across to keep the door mechanism from opening. I can push it back and open the door. Unfortunately, when I plug the DVD player back in, the bar slides out and stops the drive door from opening. Any solutions?
  • 3 Answers
You should get the DVD door cleaned either profesionally or just do it yourself
Posted on Feb 19, 2012
Why won't my Gateway PC DVD drive close?
Are all the Windows and Gateway updates and Hotfixes in? Look for a DVD rom fix on the Gateway website support. If there is no disk in the drive and it opens, you may want to replace it. You can try a work-around, I have no idea if it will solve the problem, but at boot open the BIOS, go to Boot sequence, Change HDD to boot first. DVD/CDrom 2nd or 3rd.
Dec 26, 2012 | Gateway Computers & Internet
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
Door won't open
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
Details about this fault has been described here.
May 15, 2012 | Televison & Video
Door won't open
May 15, 2012 | Panasonic DMR-ES10 DVD Recorder
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
Microwave just won't stop
One of the door switches is defective, sometimes caused by food particals this is a safety issue and should be corrected.
Mar 08, 2012 | GE JE1540 Microwave Oven
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
We have a Samsung Smart TV. We cannot get the signal and have installed a Digital Satellite Receiver. We have a Magnavox VCR and a sony DVD Player. We owuld like to attache the same to our TV and watch...
Depending on your Satellite receiver's output type (i.e. HDMI or Component - Red, Green, Blue) you should connect to your tv's appropriate external inputs. Example: if you choose to connect the receiver via HDMI, then you use the SOURCE button on your tv and select the correct HDMI input you have connected your device to. If connected by Component (Red, Green, Blue) then use the SOURCE button to select the correct Component input, and so on.
Note: HDMI is the best connection type - you won't be able to access your receiver from the tv's built in tuner.
As above explanation, your VCR and DVD devices should be connected to your tv in the same manner - unless it is a combo unit (VCR & DVD in one), in which case this device can be tuned into your chosen tv channel (via the tv's tuner).
Note: if you have one of the latest SMART tv's, it should already have a built-in "Hi Definition" tuner which will allow you to watch free digital tv broadcast (DVB).
Hope this helps...
"Please rate this solution"
Aug 28, 2011 | Samsung Televison & Video
The machine will not open the DVD Drive. When I push the eject button the display indicates "OPEN" but nothing happens. Is there a way to open the drive manually?
No,if u forced it,will damges the little motor that help it to open the dirve door.Unplug the unit,hold the unit in ur hand tight over head shake it a few times,this will help,what caught inside that stop the drive door from opening.Wait like about an hour later to replug it back in the unit,will be resetting itself back to the factory setting,will help help the unit too.
Dec 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
I have a Toshiba SD2019U DVD player and the door won't open. When I turn it on, it makes a rumbling sound and displays "opening", then continues to rumble then changes to "closing" and...
i think there's a broken or loose gear.or someone put something small that stop the door from openning.
you can try to open the unit up and turn the power on
and check what hinders the door from openning.
May 08, 2009 | Televison & Video
Televison & Video Logo
222 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
