Question about Numark Audio Players & Recorders
Numark ttusb skipping
Can't get counterweight to properly balance toner arm. results in skipping
SOURCE: Not hearing songs I transfered to my i tunes from my Numark TTUSB
Open Preferences, Sound, your input should be  USB Audio Codec (turntable).. make sure your output is NOT USB Audio Codec, rather, headphones (for external speakers plugged in there)... thats how i have mine set up...
Posted on Jan 25, 2009
  • 69 Answers
SOURCE: Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
Posted on Aug 07, 2009
57 varieties
  • 1653 Answers
SOURCE: where can I download gracenotes software for free
just do a Google or Bing search for gracenotes software download
Posted on Sep 10, 2009
Grubhead
  • 5151 Answers
SOURCE: my turntable skips on brand new records. i even
Keep turning the weight control up a little at a time to see if it solves it.
Posted on Jan 04, 2010
dunnbiker
  • 8546 Answers
SOURCE: how do i hook up a numark ttusb turntable with
Your PC and its sound capabilities will determine the actual hookup.
http://www.retrevo.com/support/Numark-TTUSB-manual/id/530ci970/t/2/
http://www.soft82.com/download/Windows/Virtual_DJ
http://www.virtualdj.com/download/free.html
In the upper right corner is a CONFIG button.
Posted on Jan 14, 2011
Why doesnt the volume on my ttusb numark record player work?
This is only a turntable. You will need an amp with a phono input to get any sound. For more information, please visit my website at audioserviceclinic.com. Thank you.
Oct 29, 2013 | Numark ttUSB Turntable
Installation cd for numark ttusb
have you tried the NUMARK web site
Mar 17, 2013 | Numark ttUSB Turntable
Platter vibrates; doesn't rotate smoothly
Do one thing Remove the palter and put one drop of lubricating oil in the center shaft. Also put one drop in the motor shaft. Be carefull do not drope the oil in motor pulley. If so clean the pulley with a cloth. Because it will cause slipping the belton the pulley.Then put the plater back. Rotate the plater with arms for some time. Then check.
Ajin
May 07, 2012 | Numark ttUSB Turntable
Where is the serial number on the Numark USB turntable?
Same problem if anyone knows. Numark certainly don't want to.
Aug 06, 2011 | Numark ttUSB Turntable
My brand new audio-technica AT-LP60 turntable has skipped on every single record I've played in it (even brand new ones). Always happens at the same spot - towards the end of the record, halfway...
hi,
Do one thing adjust counterweight on the back of the arm to 1.5gm or 2gm by rotating the counterweight. It will give some more pressuer on the styles and will avoid the jerking
ok
Aug 04, 2011 | Audio Technica AT-PL120 Turntable
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
I have a denon DP-7F direct table (1989)ust wondering about the point of the arm the head of the cartridge housing is very close to the record any way to get that adjusted higher?
If the tonearm balance and tracking force for your cartridge are adjusted correctly, ignore it.
Register and download the manual for free at vinylengine.com
http://www.vinylengine.com/library/denon/dp-7f.shtml
Eeeww, page 8 says the counterweight snaps on and the tracking force is factory set. Any self-repecting turntable should have precise manual balance and tracking adjustments. Or your counterweight is not on? Either way, I'd look seriously at getting the stylus checked for excessive wear if it's tracking too heavily. The manual says 500 hours of normal use. You'll be carving up your recordings.
Maybe post the question to the guys at Vinylengine
Apr 30, 2011 | Audio Players & Recorders
Arm weight needs adjusting...albums are skipping. how do I do this? thank you.
If you have a guard for the stylus, consider using it or be very careful with the following.
To balance the tonearm, rotate the counterweight at the back of the tonearm one way or the other until the arm floats - doesn't go up or down, just sits there level. Set the scale to zero.
THEN, rotate it inward (clockwise when viewed from the back) until it is correct for your cartrridge. If you're not sure of a correct setting, start with 1.5 gm and see how that goes.
If the TT has an anti-skate adjustment (a small knob with scale around the base of the tonearm, set that to whatever you set the tonearm pressure for.
If it still doesn't track OK, add pressure in 1/4 gm increments but do not exceed 2 gm in all but very rare cases.
Jan 27, 2011 | Technics SL-BD22 Turntable
Record keeps skipping arm won't move toward center of record
Sounds like your arm is tracking too light. To proper set the tracking weight on most units you need to zero the arms balance so that it is balanced just at the surface of the record. Once that is done using the weight on the back of the tone arm, or whatever system your unit uses, there should be an adjustment by turning the weight on the arm or perhaps a lever near it. You owners manual should really explain all this and give the recommended tracking weight in grams and fractions of grams. Each weight is different for different styli. Take a look at your operation manual and adjust the weight. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 22, 2010 | Numark ttUSB Turntable
67 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
