Question about Vacuums
O-Cedar Pro-Mist trigger doesn't work
From the first time I bought this mop, after the first squeeze, the trigger doesn't work. No cleaning solution comes out of the mop. Is there a way to fix this?
This person is asking about an O'Cedar Pro Mist Mop. Not a vacuum or steam mop...
I too have problems with the pro mist handle not working... I called the customer care line at 1800-543-8105 and they are replacing my mop for free. You can also try to take it apart and fix it yourself, but I did that and I cant remember how it goes back together! lol Basically a spring comes loose from the pole inside of the mop handle, and that is why there is no tension in the trigger.
Posted on Aug 16, 2012
    New Friend:
I have had a similar issue. It was related to the valve/pin in the nozzle of the bottle that allows it to be held upside down without leaking. A gasket was sticking to both the valve and the nozzle, restricting the flow of water.
I solved the issue by putting nozzle tip up on the ground and hammering the valve out with a punch. I now have to hold the mop upside down to insert/remove the bottle but the problem is solved.
Posted on Jan 03, 2018
    New Friend:
I solved the problem when I took the cap off of the bottle and soaked it in really hot water that had stopped boiling for about 10 minutes. Put it back together and it works again. I thought it would not be that simple but yes it was.
Posted on Aug 03, 2017
3 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: I just bought and assembled
Hello, iamrgo
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my own personal time
to see if I can help. Even though this a Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about vacuum cleaners and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just tried to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry.I do not get paid to help people on the site, I do it cause I like to help.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 30, 2011
wentlanv
  • 710 Answers
SOURCE: my gold shark pro mop (costco) steams inside the
Hi escada48036,
Sorry to hear about the problems your having with your Shark. One of our experts, heatman101 wrote a tip we have in our files. Here is the webpage for the tip: http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
Copy and paste this into your browser and the page will open up for you.
In the tip he describes pulling off the attachment and finding a small hole that comes out of the tank and leads to the hose. From your description, this sounds like what is plugged up. I think once you clear that, steam should flow through fine.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Jul 29, 2011
Rubbermaid Reveal mop trigger sticking
I bought 2 rubbermaid reveal spray mops before I figured this out. You'll need a Phillips and flat head screwdriver & a can of WD40. On the compartment that holds the liquid cleaner bottle there are 2 screws and 1 screw on the connector piece to the mop head. Unscrew all three. The one by the mop head came out and the other two stayed in their holes. Then with a flathead screwdriver gently pull the seam along the side apart. You only need 1/2-1 inch of a gap. If you pull it open all the way you'll pop a few other pieces out of place and have to piece them all back together- so gently! Then spray some WD40 in along the exposed spring using the red straw that comes with the can. Close the gap, hold it together and try the trigger a few times. If the trigger is still sticking spray more WD40 in until it frees up. Then screw your screws back in and it's as good as new!
Dec 03, 2013 | Rubbermaid Reveal Spray Mop Kit,...
Shark steam mop S3501A doesn't make steam
My shark wouldn't steam with the head on so I cleaned the holes with a paper clip and then poured CLR through it and it is working now.
Aug 02, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I think my steam mop head is stopped up. How do I take it apart to fix it? It is not steaming.
heatman101
May 09, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I bought this shark steam mop and used it for a couple of times in a year.then it all of a sudden stopped working.can u plz help!!!
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
0-0-[]
Feb 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
4,242 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
