Question about Bernina Sewing Machines
My bernina activa 220 won't turn on. It's showing no signs of life! Help, it's a fairly new machine but it's been sitting in dormant for a while unused. It worked just fine the last
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
SOURCE: Bernina Virtuosa 153 QE Won't turn on
If you've got bad luck like I do, you probably blew out the circuit board! It took my Bernina dealer 4 months to get another from Sweden; thank goodness they gave me a loaner.
Unfortunately, it happened again right after I picked it up from the dealer, and they have to find another circuit board for it! It's not a problem with my electrical wiring because the loaner ran just fine.
It's very, very frustrating because I'm a small business and need my machine running!
Posted on Aug 17, 2009
  • 11 Answers
SOURCE: needle threader is not working bernina 220 activa
Use a magnifying glass to see if the little hook in the needle threader is bent so that it is not going through the eye of the needle. You might be able to gently bend it back with tweezers.
Make sure that your needle is in the upper most position when you try and the presser foot is down.
Posted on Mar 17, 2010
Zenqi
  • 208 Answers
SOURCE: My Bernina Activa 240 won't
Likely the problem is a blown fuse in the S-Print (power supply). You must have a grounding wrist strap when working with a Bernina Activa. They are extremely sensitive and can easily destroy the main circuit board if you don't use a wrist strap. You can get one at Radio Shack for less than $5. The power supply is the square 1/3 of the machine on the back on the handwheel side. You can remove the power supply by removing the long torx screw on the rear of the machine and tilting out enough to unplug the connector. Then dismantle the power supply until you can get to the fuse. Test the fuse with a continuity tester. If the fuse is blown, buy an exact fuse. Don not deviate. If the fuse is not blown, you may need a new power supply.
Posted on Jun 02, 2011
  • 166 Answers
SOURCE: My Bernina Activa 220 won't turn on. This has
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Posted on Nov 24, 2011
How do I check the fuse in my Bernina Activa 220?
The Bernina 220 had a very failure rate of the power supply circuit (L-PCB), ranging from a lengthy boot up time to no power at all. Suggest that you acquire a new power supply from the local Bernina dealer.
Aug 04, 2014 | Bernina Sewing Machines
My Bernina 210 Activa won't power up. I had it tuned up by a Bernina tech a few months ago and this is the first time I've pulled it out. No power/nothing. Seems like I'm just missing som
seems silly, but did you remember to plug it in? If you used a power strip, did you remember to make sure the strip is turned on?
Make sure the connection is plugged into the machine.
Good luck
Jan 23, 2013 | Sewing Machines
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Nov 05, 2011 | Bernina Activa 130
Bernina Activa won't turn on
Lets start at square-one. Have you checked the plug fuse ? Have you checked that the 2-pin mains plug is firmly inserted into the socket on the back of the machine ?
If yes to the above ... are there any lights on at all ... sewing light, display backlight ?
If it's completely dead, it's most likely the power supply 'L'-print which is a separate module screwed into the back of the machine below the spool holders. Your best bet is to get the machine checked-out by a Bernina service agent.
Oct 28, 2011 | Bernina Activa 130
My Bernina Activa 240 won't turn on. I checked the outlets and they are fine. I even plugged it into different outlets hoping for something to work and it didn't. Can I take it apart and fix it...
Jun 02, 2011 | Bernina Activa 140
Is there a way to lower the feed dogs ''a little''?
I thought this was free . . . didn't know I'd be asking to join. So, I called the shop where I purchased the machine. They were able to help me fix the problem.
Nov 12, 2009 | Bernina Artista 180
Operating manual
Unfortunately this is a purchase site. The closest I could get would be for an Activa 220 230 240 . You can download the manual.
Check the picture on no. 7 and see if this isn't your machine.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Hope this helps. Luck!
PS Sewusa is no help.
Mar 01, 2008 | Bernina Activa 130
Owners manual
Dec 20, 2007 | Bernina Activa 130
Sewing Machines Logo
663 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
