Ipod classic doesn't charge new battery
With new battery fully charged, and when first inserted worked fine, and initially showed an icon of battery charging but still did not charge either with chord to computer, nor direct to outlet or in docket. This is the second new battery and the same problem. Even when in the docket and battery charged it plays fine and leaves you to believe it is charging, which it is not, the battery then goes dead and unit now doesn't respond.
  • 111 Answers
SOURCE: Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Posted on Oct 28, 2008
scott_77
  • 48 Answers
SOURCE: ipod isn't recognized by my PC
Try putting it into disk mode. http://support.apple.com/kb/HT1363
Posted on Apr 30, 2009
  • 502 Answers
SOURCE: battery icon won't show when charging...
I think on the iPod classic it doesn't change the battery logo other than showing the little lightning bolt when you plug it into the charger. However if it doesn't hold a charge after leaving it connected for a while, If hard resetting and restoring fails and If you're out of warranty there are third party ipod repair services that will replace the logic board or battery depending on what's wrong. There are also ipod repair tutorials that show you how to replace the logic board yourself, if you're comfortable with taking things apart, parts are usually on auction websites.
Posted on Jun 24, 2009
Nomodo4u
  • 863 Answers
SOURCE: Ipod Touch Battery
Your battery is fu.k.d up.  This thing ships with half a charge and your supposed to fully charge it before first using it.  Even though every genius out there will say that these batteries don't retain memory charge.  They are wrong.  You have set your battery memory to say full when it is only 1/4 fully charged.  Take the thing back to the store and exchange it for a new one if your within your 30 day window.  Take the thing back to the Apple store and exchange it out for a shiny new one if your within your 1 year window.  You don't need a receipt at the Apple store, cause they can just look on the back of the ipod and type in the serial #.  That tells them if the ipod was sold within the year or not.  Apple won't exchange the thing out if you dropped it hard or exposed the thing to liquids.
Posted on Oct 31, 2009
  • 3278 Answers
SOURCE: I have two ipod video's
Hello.
Try charging your A1059 with a Firewire cable.
Hope this helps.
Posted on Jun 06, 2010
Shuffle not working
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked.
When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Oct 15, 2012 | Apple iPod classic 6th Generation Digital...
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
I have connected my nanomax ipod to the computer and it is not charging.how should i charge it?
Good morning, afternoon, evening or night; whatever time you are viewing this solution post. Thank you for choosing FixYa to solve your problem. So you have connected your Nanomax iPod to the computer and it's not charging like it's supposed to, and you want to know how you should charge it properly? There are two ways you can charge the battery - charging via your Dock Connector to USB Cable, or the Apple USB Power Adapter (which is sold separately). Here are the step by step instructions to charging your and Nanomax.
Using the Dock Connector to USB Cable
  1. Using your Dock Connector to USB Cable, plug the dock connector end to your iPod and plug the USB end to your computer. Make sure the computer you are using has a USB 2.0 port (check your computer's technical specifications to see if it's USB 2.0 certified). Most USB ports on the keyboards of laptops do not provide enough power to perform charging activities. If you have a Docking Station, plug the docking connector into the station and placed the iPod in the station as well.
  2. Make sure your computer is fully awake and not asleep (meaning in sleep mode).
  3. A fully charged battery takes 3 hours to complete. An 80% charged battery takes an hour and 30 minutes. The battery is charging when it shows the charging icon (a battery not fully shaded in green, with a lightning bolt).The battery is done charging when the "fully charged" icon shows (a green-shaded battery with a 2-prong plug showing).
  4. When you are done, disconnect the cable from your computer.
Using the Apple USB Power Adapter
  1. Connect the Alternating Current (AC) Plug Adapter with the power adapter (if connected already, skip this step).
  2. Using your Dock Connector to USB Cable, connect the dock connector end to your iPod and the USB end to the power adapter.
  3. Plug the power adapter into a polarized wall outlet or surge protector outlet.
I think you connected everything correctly, but the USB port on your computer did not have enough power to charge your battery. If that's the case, you will have to find a computer that has a USB 2.0 port on it (like a desktop PC or MAC, or a car adapter charging device) and connect to it, or use the USB Power Adapter (sold seperately). I think this pretty much answers your question. I hope this benefits you the best way possible. Once again, thank you for choosing Fixya as your one-stop solution spot for your problems. Have a good day, evening or night; whatever time you are viewing this, and visit us again the next you need assistance troubleshooting.
Apr 27, 2011 | Audio Players & Recorders
Wondering how to get brand new iMT620 inmotion classic to charge the battery for the first time?
You just plug it into the wall and wait four hours. The battery icon will show full when the battery is completed charged.
Jan 29, 2010 | Altec Lansing inMotion Classic Portable...
My 160 gig ipod doesnt charge anymore.
Does the battery icon show to be taking a charge? If so, you most likely need a new battery.
Jan 05, 2010 | Apple iPod classic MP3 Player
Battery icon won't show when charging...
Have you already reset the iPod? If not I would try that first. It may be that your battery is shot though. It's not a relatively expensive repair though.
To reset the iPod Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If that does not start the iPod to charging you can go to (www.rapidrepair.com) and view free repair guides that show you how to replace the battery as well as how much it will cost to replace. Good luck. Hopefully the reset resolves your issue and you will not need a new battery. Let me know how it turns out
May 27, 2009 | Apple iPod classic MP3 Player
TMR-BT8iP not working
this was made to work with any older genegarion ipod that works on firewire power not usb
most ipods
this is not fully compatible with the new iPhone,iTouch new nano and the ipod classic
May 07, 2009 | Sony Bluetooth Wirleless Transmitter for...
I pod problems
Hi
I think your battery may be going bad or you need to purchase a wall charger to fully charge your battery. Charging your iPod on your computer works fine for a while, but as the battery gets older, it needs more charging and often it doesn't get enough from the computer. Try a wall charger first. Charge it all the way up until it stops charging. If it still shows a low battery you need to have a new battery. There are a lot of places that can do it. Hope that helps.
Dec 20, 2008 | Apple iPod MA446LL/A MP3 Player
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
60 GB iPod won't recharge
probably, when you replaced the battery, you didn't properly inserted its contact to the board connector, so just open the ipod again and re-install it, make sure it's all the way down into connector
Aug 19, 2007 | Apple iPod MA446LL/A MP3 Player
51 people viewed this question
 Grubhead
Grubhead
