Question about Frigidaire GLEQ2152ES Electric Dryer
Sometimes it heats, and sometimes it wont
When I start a load in the dryer, sometimes it will heat up and dry them. But sometimes it runs the whole cycle and never gets warm
  • satman302 Oct 26, 2008
    sorry, the model number is fdg436rbt1, it's a gas dryer
  • Anonymous May 11, 2009
    The dryer runs good but it doesnt get warm and dry the clothes.
    Problem Solver:
  • 6 Answers
I'd check for a clog in your vent line. I had the same problem before.
Posted on Nov 19, 2008
The dryer wont heat-it over 5 hrs to dry a load. it would not turn off on automatic side & just keeps running. it turned off on the timed side
If it's not making heat the humidity sensor will never dry out, therefore it keeps running. It sounds like your heating element is bad.
Jan 20, 2014 | Whirlpool GGW9200L Gas Dryer
Hiow old is my Kenmore Dryer 110 62952 100 It has heat; starts to dry; then stops. Sometimes it finishes drying a load and sometimes not.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Kenmore 62802 Electric Dryer
Dryer wont dry, no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 16, 2010 | Smeg WDF16BAX Front Load Washer / Dryer
Amana model 2330aww....runs but does not heat up....just started happening, dried one load then it stopped heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 15, 2010 | Amana NDE2330AY Electric Dryer
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
No heat after drying several loads
the vent in your house may be stop up in the wall.
Jun 15, 2009 | LG DLG3788W Gas Dryer
Electric Dryer Heating problem
Remove the rear vent and run a load on time dry for 45 minutes.
If it dries, repair your exhaust vent.
If not, replace your heating element.
Nov 18, 2008 | GE DBXR453EV Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
157 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
