Question about Lexmark Prevail Pro705 Wireless All-In-One InkJet Printer
Instructions for refilling cartridges on a Lexmark Prevail Pro705 printer
Where is the refill hole, etc. for all colors? I can't find any information on instructions to refil their 100xl cartrdiges.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 544 Answers
The lexmark 100xl can be refill but would not usable because there is a chip in the cartridge that monitor the ink level of the original ink supply. If you want to refill the lexmark 100 cartridges, you need to purchase the 100a or the 100xla. Cartridges can be purchase at www. lexmark.com. The refill hole are located at the top of the cartridge. Remove the top label and you will see the hole. Use a good quality ink to refill.
Posted on Feb 23, 2012
  • Official Brand Answer
  • 3,344 Answers
Please note that Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Posted on Feb 20, 2012
map9966
  • 2351 Answers
SOURCE: refill colored ink, what holes, lexmark x5470
To open the printer, just above the front control panel you use both hands & pull upwards. The whole top of the printer will open up. The ink cartrifges will be close to the center of the opening. The printer should be on for this. There are two ink cartrages. The one with the black lid is for your black ink. There is a small tab in front of the cartridge lid. Push down on the tab & the lid will open. Remove the old ink. Remove the tape that is protecting the the bottom & copper back side of the new ink. Place the ink into the printer. The copper back that runs from the bottom & up the back side about 3/4" goes into the printer cartridge. The colored ink goes into the other cartridge holder, it's lid is blue. Again press the tab just in front of the lid & it will pop open. Repeat the above removing the protective tape & install the ink.
The ptinter will want to run either a test page or allignment page or both. You will need your manual. If you do not have your manual you can download it from this site. Click the link below.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=f7f0a21c03aee016b79da0cdbb74cf9f&q=Lexmark+X5470
Click "Start download" & save it to your Pc.
Have fun!
please vote...
Posted on Feb 07, 2008
SOURCE: refilling lexmark cartridges x2500
I have same problem but if you will close the low or out of ink popup and then click print it will start printing. When you run out of ink refill and keep doing the same thing. Much easier that trying tocalibrate cartridge.
Posted on Jun 17, 2008
SOURCE: Refilled Cartridge
I have a Lexmark X7170 with the same type problem. Refilled without a prob for many times. The last time I couldn't use it after refill and bought a new cartridge which is already out of ink. I refilled it and after installing it I get a message that the cartridge is missing and the alignment won't work
BUT
Icalled my ink supplier to see if they knew of an anti refill device put in by Lexmark and they said that they had not heard this.. While talking I remembered that the previously I got a message while printing that the cartridge was missing but if I clicked OK the printer printed without a problem! So maybe yoy just need to skip the alignment, ignore the messages and try to print anyway. The last one I refilled is now working .
Another possibility is that after some number of refills the cartridges just quit and you need to occasionally purchase a new one - this I heard previously from my supplier
Good Luck
BL.
Posted on Jul 02, 2008
  • 83 Answers
SOURCE: refill instructions for lexmark 23 & 24
1. Peel the label off of the top of the cartridge.
2. See the squiggly lines leading to small holes.
3. Drill the holes larger using a 1/16th inch drill.
4. Hold the cartridge so the contacts are away from you. NEVER touch the contacts with your fingers.
5. The top hole is Magenta (red). You can insert a syringe needle into the hole and test the color if you are doubtful. Left is Yellow and Right is Cyan (blue).
6. Fill a syringe with the appropriate color and insert it into the cartridge until it is at the bottom. Lift the syringe back out until it is halfway between the bottom and the top. SLOWLY inject the ink (about 6 to 8 ml) into the cartridge, too fast and you will trap air inside. Watch the hole and when the ink starts to come out remove about 1/2 ml of ink.
7. Clean your syringe and repeat this process with the other colors.
8. Verify ink flow by pressing the ink head against a wet paper towel. You should see three solid lines of color.
9. Replace the label and install the cartridge into your printer.
10. Print a test page and run a cleaning cycle if print results are unsatisfactory.
Posted on Sep 07, 2008
SOURCE: Refill cartridge for lexmark X6570
please note that I am not an expert, in this field just an attorney and that is why I am putting my full disclaimer right here at the top---That i am not an expert but only speaking from experience.
Earlier this morning, I just pulled the cartridges to check the Lexmark print (X6570) cartridge numbers (41&42). When I typed these numbers in on inksell.com to retrieve the price and other information for these cartridges, they did not have any refill kits or anything of that nature for these specific cartridges.
To answer your question about why the printer is not detecting that your cartridge is full is probably because the cartridge has a chip in it that essentially disables it once the original manufacturer ink is empty. tHEY [Lexmark & Dell] do not want outside competition In other words, the printer manufacturers make the bulk of the money on selling new cartridges (for a fortune) . To make matters worse, they always seem to be half empty even though they are ‘brand-new’ ink cartridges The bottom line is that the faster you can go through a printer cartridge, they can sell many more of the cartridges that they are charging us a fortune for.
Needless to say, I am just going to go and get me another HP printer. My advice would be to check to see if ink-refill kits (see sites like inksell.com) are available for any future printers that u purchase.
Posted on Nov 08, 2008
How can I make printer recognize refilled cartridge on lexmark prevail pro 705
Refilled cartridges will not reset the ink levels. The printer will still recognize it as empty.
Please be advised that refilled/remanufactured cartridges could damage your printhead and will not be covered under warranty.
Nov 27, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
My Lexmark Impact S305 will not print in color.
If you're using a remanufactured/refilled cartridge, the printer will not be able to recognize those cartridges after the firmware update. The firmware update restricts use of refilled/remanufactured cartridges. That's to prevent damaging the printhead.
If you're using genuine Lexmark cartridges, please contact our technical support for assistance.
Oct 02, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
How do i set all my cartridges to work
If you're using genuine Lexmark cartridges, it should print fine once installed. If not, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
If you're getting a poor print quality, try to perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If you're using refilled/remanufactured cartridges, there's no guarantee that it would work with your printer. It will also damage the printhead and will void the warranty of your printer.
Jul 18, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Where's the ink?
Make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update. It helps maximize the life of your ink cartridges.
Printing in draft mode will also help.
Apr 14, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Lost installation disk for lexmark prevail pro705
Please visit the Lexmark website to download and install the Lexmark Prevail Pro705 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Jan 18, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
Lexmark Prevail Pro705 printer jams each attempt to print. Reasonably new, Lexmark just replaced printhead and ink cartridges under warranty and printer gave better print results than when brand new. Joy...
Make sure your printer is updated. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update on your computer. The update will make your printer more reliable and more efficient.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
I have the Lexmark Prevail Pro705 Wireless AllInOne Copier Scanner Fax InkJet Printer - after installing new cartriges (directly from HP) the printer will only print in black, and ignore any color. I have...
hi
you mentioned (directly from HP) .. this is a lexmark printer -- i am sure you mafde a type error, coirrect ?
LEXMARK -- here are two links to help you -- review these to help you resolve the issue
http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-Prevail-Pro705/catId=cat10004-category&prodId=5471-product
http://www.lexmark.com/publications/pdfs/2007/pro700/quick-ref-en.pdf, page 14 for proper cartridges
please rate me with 4 thumbs up to avail and maintain my service
Dec 01, 2010 | Lexmark Prevail Pro705 Wireless All-In-One...
Lexmark Prevail Pro705 Wireless All-In-One InkJet Printer Logo
776 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
