Question about Janome 405 Mechanical Sewing Machine
Material doesn't move
My needle does move up and down but the material needs to be pulled thru, otherwise it sews in one spot. Have cleaned machine and checked tention, stitch etc any suggestions. Thankyou
  • Anonymous Mar 19, 2014
    needle goes up and down material won't move
  • 35 Answers
Are the feed dogs engaged? Janomes usually have a feed dog sliding switch, either on the back of the sewing machine at the bottom, or behind the accessory case. Be sure the check it out. Hope this helps!
Posted on Aug 16, 2008
  • Carol Griffiths
    Carol Griffiths May 07, 2014
    there is a sliding switch thank you pity they dont mention in manual wasted a couple of hours.
My brother VX1120 will not move the material thru. The needle works and is not tangling. The material just stays in the same position and I can not even pull it thru. Need advice. TK
Check to make sure the feed dogs have not been dropped. Also, check that the stitch length is set at least to 2. If not that, then you machine probably needs service.
Jun 09, 2018 | Brother Sewing Machines
I have a new ruby sewing machine the material will not pass under the foot. The needle just goes up and down in one spot
Make sure the stitch length is set high enough to actually move the fabric. Also check that the feed dogs are actually moving forward and backward when stitching (they should move from front to back, then drop below the needle plate and move to the front, where they rise again,)..
Feb 02, 2018 | Sewing Machines
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
How do I stop my needle from breaking and how to I see to it that the machine is self feeding the material forward instead of me having to pull it towards me to get the stitches into the material?
The needle may be bent, but surely the material should feed away from you not towards? Is the bobbin in correctly? If you have inadvertently left the feed dogs down the material will not be gripped and stay in the same place instead of moving. Check.
Mar 27, 2015 | Sewing Machines
Janome 350 embroidery machine......when I try to rewind the thread, ( shifting the stick to the right ) the needle keeps moving up and down.....any kind of help would be very appreciated.....the deale
Try to find the exact spot on the wheel to make the needle stop. Try different spots to get the one that does not move. You may need a service. You could also remove the thread until you are ready. The needle would go up and down but without thread will not cause havoc.
Jul 29, 2014 | Janome America Inc 350E Memory Craft...
I have cleaned and oiled my sewing machine according to book instructions. Before and after, it doesn't want to pull the material. Seems to want to sew in one spot. Can you help me know what to do?
check the feed dogs in the needle plate area to see if there up or down
look in the book and find where the lever is to change the position of the feed dogs. when there up the fabric will move, but when there down it stays in one place
Sep 10, 2011 | Kenmore Sewing Machines
I have been trying to make a buttonhole but the top thread keeps breaking and the threads are all snarled up underneath the material. what am i doing wrong? i have a brother ls2125 machine maria
Firstly have you interfaced the material that you are buttonholing on? You will never get a good buttonhole otherwise. Also start each new project with a new needle matching the size to the weight of fabric. Good guide available here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
Top thread breaking is usually because the tension is too tight or the thread is catching somewhere in the thread path from the spool to the needle. Also check that the needle doesn't have a burr on it somewhere, or is blunt.
Thread snarls underneath the fabric is usually caused by top thread tension issues. You will need to rethread top and bottom and CHECK that the thread is in tension correctly. So lower the pressure foot and pull the top thread just before the needle - does it feel hard to pull? If not, then the thread is not in tension. Rethread top again, checking the tension dial is set to 5 and the thread is correctly pulled between the tension discs. And always hold the two thread tails at the back of the sewing area as you start each new seam to avoid these being pulled down into the bobbin area and getting jammed up.
So, rethread, test sew and get the top tension sorted, a nice straight stitch happening, then try the buttonholing sequence again.
Apr 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
When the needle descends it gets stuck as it enters the bobbin case area. It will only release if I move the bobbin. The thread from the needle gets knotted up and pulls the fabric down into the bobbin...
Could be a few things. Absolutely minutely check that the top thread is threaded properly. Otherwise, it could be: Old thread. incorrect thread for the material. wrong size or blunt needle. or incorrect tension on needle I had this problem and I was missing a part of threading even though I have been sewing for years. :)
Oct 08, 2017 | Brother LS30 Mechanical Sewing Machine
Machine will not feed material thru. Needle goes up and down but I cant pull material thru to catch the stitch
Use a fresh needle and install with flat side facing rear of machine. Is your clutch engaged, after you wound the bobbin? Do you have an owners manual? If not, go online to brother-usa.com and download one for free. It is good to have a copy on hand anyway. Good luck
Sep 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Nov 13, 2008 | Brother CS-8150 Computerized Sewing...
Janome 405 Mechanical Sewing Machine Logo
352 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
