Question about Ovens
Kitcheaid oven keypad not working
Kgsa906pss kitchenaid gas oven stopped responding---except certain buttons---# 7, 8 work, "other foods" button work--all the other do not work. I purchased it on july 1, 2006, this occured 2 weeks ago---i am not sure if power surge from Hurrican Ike (houston, tx) would cause part of the keypad to go out---please help---can i replace it myself? or do i need to have an expert do it?! please help.
AT.
Powerman
  • 68 Answers
SOURCE: GE Profile Spectra Electric Oven Self clean malfunction and F7 error
I can't help with the burn marks, but have considerable experience with the F7 problem. Click on the following link for my solution:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success. Please let me know if this works for you.
You can email me at hutchipop@yahoo.com
Posted on Nov 22, 2007
barkencoa
  • 3463 Answers
SOURCE: oven has suddenly stopped working but the fan is
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Oct 11, 2009
Testimonial: "many thanks for yur help"
EllaWatson25
  • 725 Answers
SOURCE: KitchenAid gas range - Err message F5 E7 - cannot unlock door
Normally when storms hit your oven, the electronic control board goes out. That's what has happened to this oven.
Posted on Oct 25, 2009
SOURCE: Some numbers on panel does not work
I have the same problem. I can't see how maytag can say there are no quality issues since they don't track how many calls they get about the same problem.
Posted on Nov 28, 2009
  • 53 Answers
SOURCE: THE OVEN DOESN'T WORK...F1 ERR
You need to replace the clock control
Posted on May 21, 2010
Testimonial: "He has confirmed what I have been told by others. I just wish I knew how to do this by myself. I guess it's time to call Sears. :("
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
Replaced control board and keypad but oven buttons still not working
I pulled the schematic there is a thermal fuse on the neutral wire going to the control you should have 120VAC at terminals P4-3 and P4-1 if not find the fuse back trace from P4-1
Feb 12, 2014 | Whirlpool Ovens
JKP27B0W1BB WHEN I PRESS ALL THE KEYPADS AT TOP THEY ALL WORK EXCEPT THE START BUTTON ...
It is a good chance that that button is bad on the keypad. the key pad will need to be replaced.
Feb 02, 2014 | GE JKP27 Electric Double Oven
The clock is still working but nothing happens when any buttons are pressed
you may have a bad connection between the touchpad to the board....
usually one must replace that touchpad console assembly to repair,,, i would check your owners manual or download one at kitcheaid.com and check the warranty on that some had 5yr parts warrantys if that was the problem... hope this helps
Feb 06, 2010 | KitchenAid Ovens
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
I had food put into the oven and pressed clean instead. Now I cant open the oven door to get the food out. How do I open door?
If you're in a hurry, try holding down the clean button for 3 seconds. This may stop the clean mode. If not, respond back and I'll get you additional info.
Apr 06, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Setting the oven to come on at a certain time
I have a neff u1722 but I think the settings are pretty much the same. To set a coming on time first press the button with side by side triangles on it until the symbol l->l flashes then rotate the plain button next to it to the length of time you want the food to cook for. After about 4 secs the normal time will come back on. Then press the side by side triangle button again until the symbol ->l flashes then with the plain button rotate again to set the time you want the food to be cooked for. Hope this works
Jan 16, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
