Question about HP Office Equipment & Supplies
My computer had some issues so I took into the computer store and they had to clean the system out, when I received it back I had re install all of my programs. I couldn't get my scanner to work at first so I un-installed it and re installed it now it works but it keeps telling me PHOTO GALLERY Please wait while windows configures photo gallery PHOTO GALLERY The feature you are trying to use is on a CD-ROM or removable disk that is not available. Instert the photo gallery disk and click ok...... I insert the disk and it tells me to restart I do that and it still doesn't work PHOTO GALLELRY Error 1706. No valid source could be found for product
  • 70 Answers
Try using windows install clean-up utility
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
great tool.
Posted on Oct 26, 2008
Mercury sable 1998 WON'T pass smog. Check engine
PO402--EGR Flow Excessive Detected
There are other components besides the
egr valve in that sytem,so you got things to
diagnose there you skipped over
PO443---Evap Control System Canister Purge
Valve Circuit Malfunction
PO1409--EGR Vacuum Regulator Solenoid
Circuit Malfuntion
PO420 & PO430--Catalyst System Efficiency
Below Threshold---Basically worn out exhaust
converters you will need to replace
Advice--take to a repair shop & go thru the entire
car & resolve ALL Issues
Oct 18, 2012 | Cars & Trucks
Error:1923 service office source engine (Ose) could not be install
You remove a prerelease version of the 2007 Microsoft Office programs. If you then try to install the original release version of the 2007 Office programs, the installation is not completed successfully. Additionally, you receive the following error message:
Error 1923: Service 'Office Source Engine' (ose) could not be installed. Verify that you have sufficient privileges to install system services.
To work around this issue, restart the computer after you remove the prerelease version of the 2007 Office programs.
Also optionally clean your registry with a good registry cleaning software.
Jul 13, 2011 | Computers & Internet
I had a bad virus on my dell 8200. My friend took
Since your 'friend' took everything out of your hard drive you'll need a Windows CD (XP, VISTA). Without installing Windows back onto your system you're out of luck.
I would hope your friend has a copy of Windows he can use to restore your computer to a working order. If not, keep him as far away from your computer as possible!!
If you can't find a copy of Windows to install you'll have to purchase a copy at a retail store or perhaps online at TigerDirect.com or NewEgg.com.
Dec 29, 2009 | Dell Computers & Internet
Error 1335. The Cabinet file Data1.cab required for this installation is corrupt and cannot be used.
When you try to install Microsoft Office 2000 or Microsoft Office XP, you may receive the following error message: Error 1335-Cannot copy cab file Office1.cab. The file may be corrupt. When you start the computer in Safe Mode and then try to install Office, you may receive the following error message: The Windows Installer Service could not be accessed. This can occur if you are running Windows in Safe mode or if the Windows Installer is not correctly installed. You may receive this error message even when the Office CD-ROM package works correctly on another computer.
When you try to install Office while you are logged on to the computer with administrative rights, you receive the same error messages. uparrow.gifBack to the top CAUSEThis error can be caused by dirty media, CD-ROM read issues, or problems with me... loadTOCNode(1, 'cause'); This error can be caused by dirty media, CD-ROM read issues, or problems with memory allocation. uparrow.gifBack to the top WORKAROUNDTo work around this problem, try the following methods. Method 1: Clean the CD-... loadTOCNode(1, 'workaround'); To work around this problem, try the following methods. uparrow.gifBack to the top Method 1: Clean the CD-ROM loadTOCNode(2, 'workaround'); Use a soft cloth to gently clean the disc. uparrow.gifBack to the top Method 2: Change the memory settings for installation loadTOCNode(2, 'workaround'); To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
uparrow.gifBack to the top Method 3: Install Office by using a flat folder loadTOCNode(2, 'workaround'); To install Office by using a flat folder, follow these steps:
  1. Clean boot your computer. For additional information about how to clean boot Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 310353 (http://support.microsoft.com/kb/310353/ ) How to perform a clean boot in Windows XP
  2. Save a copy of the Microsoft Office CD-ROM to your computer's hard disk. To do this, follow these steps:
    1. Start Microsoft Windows Explorer. To do this, right-click Start, and then click Explore.
    2. Create a new folder at the root of a hard disk volume, and then name it "Flatfile" (for example, C:\Flatfile).
    3. Locate the drive that contains the Microsoft Office CD-ROM, and then copy all the contents of the Microsoft Office CD-ROM into the C:\Flatfile folder. To do this, follow these steps:
      1. In Windows Explorer, click the CD-ROM icon (or DVD-ROM icon) that contains the Microsoft Office CD-ROM.
      2. On the Edit menu, click Select All.
      3. Paste all the files into the new folder. To do this, drag the selected items on the right side of the Explorer window into the C:\Flatfile folder on the left.
        Note If you receive the "This Folder contains "X" hidden files" error message, follow these steps:
        1. On the Tools menu, click Folder Options.
        2. Click the View tab.
        3. Turn on Show Hidden Files and Folders.
        4. Turn off Hide Protected Operating System Files.
        5. Click Apply, and then click Ok.
        Note If there are errors during the copy process, this can indicate problems with the CD-ROM (media), a dirty CD-ROM drive, or a problem with your hard disk.
  3. Restart your computer the way that you typically do, and then install Microsoft Office from the C:\Flatfile folder onto your hard disk.
uparrow.gifBack to the top Method 4: Install only one Office program loadTOCNode(2, 'workaround'); Install only one Office program, such as Microsoft Access. To do this, select a Custom install, and then cancel the selection for all but one of the Office programs. If the Setup program is completed successfully, restart the Setup program. Restarting the Setup program will take you into Maintenance mode. Click Add/Remove Programs, and then click the programs that you did not install in the first installation of Office. uparrow.gifBack to the top Method 5: Contact Microsoft loadTOCNode(2, 'workaround'); If the previous methods do not resolve the problem, contact Microsoft. For information about how to contact Microsoft, visit the following Microsoft Web site: http://support.microsoft.com (http://support.microsoft.com/) uparrow.gifBack to the top APPLIES TO
  • Microsoft Office XP (Setup), when used with:
    • Microsoft Windows XP Professional
    • Microsoft Windows XP Home Edition
  • Microsoft Office 2000 Premium Edition
  • Microsoft Office 2000 Professional Edition
  • Microsoft Office 2000 Standard Edition
  • Microsoft Office 2000 Small Business Edition
  • Microsoft Office 2000 Developer Edition
  • Microsoft Access 2002 Standard Edition
  • Microsoft Excel 2000 Standard Edition
  • Microsoft FrontPage 2000 Standard Edition
  • Microsoft Outlook 2000 Standard Edition
  • Microsoft PowerPoint 2000 Standard Edition
  • Microsoft Word 2000 Standard Edition
Sep 15, 2009 | Computers & Internet
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
Cannot install windows vista ultimate 64 bit on my computer when I have xp installed. Can boot from the 32 bit version disk though but I want the 64 bit. Tried booting it from start-up by booting from CD...
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
    Note When you receive with the Get important updates for installation message, click Go Online.
  5. Click Upgrade when the Which type of installation do you want? screen appears.
    If you cannot click Upgrade and you receive an error message, go to the "Troubleshooting" section if you are comfortable trying to troubleshoot, or go to the "Next Steps" section to determine your next steps.
  6. Follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the upgrade to Windows Vista.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Perform a clean installation loadTOCNode(2, 'summary'); There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2.
Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD loadTOCNode(3, 'summary'); Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Nov 27, 2008 | Computers & Internet
I purchased a Leap Frog Read & Write Leap Pad Learning System in
I took the entire toy back to the store where I purchased it and exchanged it for a new one.
Nov 11, 2008 | Toys
Overheating problem, with fan stopping randomly
If it's overheating it's possible that either there's a problem with the fan, or the fan/heatsink is clogged with dust. If you know how to open up the laptop you can do that and use a can of compressed air to clean it out which may solve the problem. If not you'll have to replace the fan.
Feb 19, 2008 | Acer Aspire 3000 Notebook
Emachine T6216 Automatically Shuts down
Hi MIchael,
Before I start replacing hardware, I would boot to safemode, and let it run that way to see of the problem repeats. In Safemode, a lot of drivers and software that may be causing the problem won't start up.
As soon as your start your machine, tap the F8 key about twice a second. This should bring up a screen with several options. Select Safemode. You will get some warning, so just click yes on those. Your screen will look really strange, since your video drivers won't install. Let it run like that for a few hours. BTW, you won't have internet.
If that still reboots, or shuts down, chance are good it a hardware issue. Might be your Heatsink on the cpu is too dirty to cool, but the techs you took it to should have cleaned that.
Get back with us, and post how that works please.
You can also right click on My Computer>Manage>Event Viewer and look thru the different catagories. Look for issues with red marks on them. To read them, just click on them. This may give you idea what is failing.
A issues that is random is hard to troubleshoot.
Good Luck!
Jan 08, 2008 | E-Machines eMachines Desktop PC
129 people viewed this question
Ben Johnson
