Question about Campbell Hausfeld Air Tools & Compressors
I have a Campbell Hausfeld commercial air comprssor that has a moisture filter but I get a lot of oil in the hose which gets all over my air tools and clogs up my media blaster. What's going on an
  • 425 Answers
Make sure you are also running NON detergent oil in the pump. Most all oil style pumps are splash lubricated. There is often a extension on the bottom of the connecting rod that literally splashes the oil around to lubricate the pump. Regular automotive engine oil can foam up and it will end up going into the tank and also can blow out the breather, Also be careful not to over fill the pump.
Posted on Mar 09, 2012
  • Campbell Hau... Master
  • 885 Answers
If you are getting oil from the air pump in your hoses and tools your problem is in the cylinder/piston area. The piston on air pumps is very much like a car piston, depending on what model you have it has compression rings and oil scraper rings. If any of these are damaged or if your cylinder(s) is badly scored oil will get by the piston and be forced out with the compressed air to your tools. The only repair is to take the head and valve plate off and find out what parts you need to replace. If the cylinders are lightly scored they can be honed out but you can't machine them out as Campbell Hausfeld doesn't make oversized rings or pistons.
Posted on Feb 20, 2012
rayname
  • 70 Answers
SOURCE: Campbell Hausfeld Air Compressor won't start
try turning the switch off for 5 minutes the turn it back on there is usually a circuit breaker or thermal overload that can trip let me know if problem still exists
Posted on Jan 09, 2009
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
  • 73 Answers
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
Posted on Oct 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: need owners manual for campbell hausfeld vt6275
go to chpower.com and type in your model number under the header needing manual and it lists several different options for you. Hope this helps and if I have helped you with your request would you please rate this response accordingly. Thank you.
Posted on Nov 21, 2009
Looking for campbell hausfeld airless spray gun ps220a 2/3 hp operators manual Please!
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support" tab select 'Manuals/Parts Lists. Do a search for your model number and you'll be presented with the manuals and parts lists for that line of paint sprayers.
Feb 28, 2013 | Campbell Hausfeld Airless Spray Guns &...
Campbell hausfeld 60 gallon sight glass oil leak
Try here http://www.about-air-compressors.com/campbell-hausfeld-air-compressors.html
Jul 30, 2012 | Campbell Hausfeld Air Tools & Compressors
I have a Campbell Hausfeld PL1502. Air flow from the compressor is good, it won't go forward or backwards, won't even try. Air just whistles through it. I took it apart and didn't find anything obvious,...
oiling thing? thats the easy part,,its oiled every time you use it,
now it wont start then,,,ok its jamed up or the air flow and presher is to low for it,,,look under the handle were the hose fits to the gun there should be a big screw there on this screw there should be 1-2-3-4? turn it to 4,,now try it???
Aug 18, 2010 | Campbell Manufacturing Campbell Hausfeld...
How do I change the gun filter on Campbell hausfeld airless sprayer?
Assuming it is detached from hose, I would first unscrew the skinny end of the filter housing that goes into the gun at the gun handle. That's cause it looks fragile and allows easier access to the wrench positions where you break down the hex fitting from the filter housing. After unscrewing the hex fitting the filter cartridge should pull out easily for cleaning or replacement.
Apr 26, 2010 | Campbell Hausfeld Airless Spray Guns &...
Comprssor hard to turn when cold
yes in winter you should use thinner oil ~~15sae
Jan 29, 2009 | Campbell Hausfeld 26 - Gallon Air...
How to use a Ratchet
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Campbell Hausfeld Professional 1/4"...
Air Tools & Compressors Logo
334 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
