Question about Garden
Chainsaw will not stay runing - Garden
    Sergeant:
  • 316 Answers
Hello sir,, now there are two types of carb.adjustment screw covers,the old one where there are plastic over the screws,simple remove the plastic covers with a pair of needle nose pliers or cutting off,,,second are the new ones that are above the adjustment screws,which you have to take your drummel tool with the cutting blade and cut slots in the screws, after you get this done it is important to count the number of rotations in until stops make note how many. because you are going to reset the same way.now remove the screws,put to the side when you get ready to put screws in put in all the way than back out as many turns that you noted, now that is factory set there should only be a small adjustment to do. the rule of thumb is turn both out 1 1/4 turn and adjust in until saw runs smooth and idles ok, it is hard to adjust the top speed when saw is running wide open,let saw idle when adjusting top speed is easier that way, when you go to cut wood you may have to readjust top speed, the above does apply some what if you are not using fresh gas mix and dumped out the old fuel and starting with fresh,and a new plug CJ8Y,and as you know the saw has to breath in and out by this i mean a clean air filter,make sure the small screen on the muffler is not cloged,this will keep saw from running at peak speed and sawing wood, ok i have ran across a few saws to where the small screen in the muffler is cloged so the saw would idle but not run at high rpm's,if you do and check all of the above your saw should run,oh btw check compression should be above 60 to 160 lbs, hope this helps,any comments welcome,thank you. ~~
Posted on Feb 20, 2012
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
Efco chainsaw
Check carburetor,needs cleaning or choke is stuck
Sep 05, 2014 | Garden
Starts up but will not stay runing chanced IAC con value thor con scosor new key switch and have 47psi at fuel rail at key on 41psi wen runing will stay runing if i put carb claner inthor body runs fine
Cam position sensor tells computer when to synchronize injector pulse. Have you checked for trouble codes?
Check injector fuse. Injectors should have constant voltage supplied when key is on.
You didn't give year and model. Injectors are pulsed when the engine computer internally grounds an injector. You may need to check injector circuit.
Jan 31, 2014 | Cars & Trucks
CHAIN SAW QUITS RUNING AFTER WARM UP
remove the muffler and run it if it runs good without it open the muffler and clean of the screen inside
Jun 06, 2012 | Craftsman 18 Inch 2.6 Ci Chainsaw Tank...
It will stay runing
sounds like a bad on/off (kill) switch. test the switch with a meter and if it is bad - replace the switch with a new one -- you should be able to find a new one at your local hardware store.
IF the switch is good then it could be a bad wire between the switch and the coil /mag. check wires and make sure all connections are good and tight.
c...
Jan 19, 2011 | Poulan 14" Chainsaw
Saw was runing and died now it want crank
My saw also died while running and is now just giving off a gust of air on the hits it would usually crank. Is yours doing this also?
Jan 12, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Pro 38cc 90days old starts fine but wont stay runing
Try adjusting idle screw big one w/ spring on it.Clockwise 1/2 turn
Feb 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Saw runs and stops runing
My guess is that your fuel lines are cracked or have a hole in them somewhere. try installing new lines and let me know how it works.
Dryer will not stay runing
check the motor relay which is located in the console on top of the dryer
Dec 29, 2008 | Whirlpool Dryers
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
