Question about Russell Hobbs 13968 Iron
How to replace the flex cable
Dont know how to get the iron apart
My tefal steam generaitor no longer works as a big flash came out of flex at top of the iron on flex
BIG FLASH meaning what exactly . short in power cord . might be time to BIN it and replace
May 15, 2016 | Tefal Irons
Replace flex on iron model 19840
Stop using immediately! This model is faulty! Check with customer service as how to return for a refund!
Oct 16, 2014 | Russell Hobbs Irons
How to replace flex on Russel Hobbs Steamglide 18651
Either it'll have a screwed on plate near where the cord enters the iron, simply open, snip out the old, solder or crimp in a new and replace the panel. If not you'll have to replace it
Oct 07, 2014 | Irons
Russell hobbs repair
You get the flex unscrew the iron off you go.
Aug 29, 2014 | Irons
Short in wire - turns on but then shuts off with movement- then on again
THIS HAPPENS WHEN THERE IS A SHORT CIRCUIT OR THE POWER CORD IS DAMAGED.A REPLACEMENT WILL SOLVE THE PROBLEM.
Regards.
DON'T FORGET TO RATE MY SUGGESTION
Jul 06, 2011 | Black & Decker D2030 Iron
My Rowenta Power Glide DE-08 iron has stopped working. Once, if I moved the cord around it worked. So I I took it apart and checked the wiring connection which seemed to be tight. I then plugged it in...
hi.
you will probably find that the cable is broken where it comes out of the iron.
this is not an unusual problem as the wire is being constantly bent and straightened here, and eventually breaks.
take the iron apart as you did before to check the connections, and cut of the last 4-5 inches of the cable and reconnect in exactly the same way it is now.
this should cure the problem.
hope this helps
Jun 18, 2011 | Rowenta Powerglide DE08 Iron
I need manuel.
i want to change the flex with a more suitable cable/plastic, but i have difficultty inlocating the bottom fixtures on the back plate of the iron, its just to good of an iron to discard.
Jan 08, 2011 | Russell Hobbs 14084 Iron
Cord
If the iron is still in warranty send it back via the shop where you bought it, the inner wire is frayed and needs replacement, if you know an electrician its as simple as shortening the flex by a few inches and reattaching it again. the inner wires twist with time and become frayed or come loose from connection
Mar 24, 2010 | Black & Decker Steam Xpress AS250 Iron...
Tefal pro express turbo water flowing out of iron and soaking the clothes
i have a tefal pro express gv8110 iron and it keeps leaking out water onto the clothes and doesnt seem to heat up. i have only had it for 22 months so im not sure why it has been doing this. it also doesnt seem to let the steam out like it used too. please could u help me
Sep 08, 2009 | Tefal Irons
When i am ironing all the power in the house goes off and it is a brand new iron
Patrick,
The iron may actually be ok. If not, remember that because it's new it will come with a guarantee.
Did you put the plug onto the iron yourself? Check inside the plug to make sure that there's no bare wires that can touch as the cord flexes as you iron. This would cause it to short and throw the power in the house.
Try using the iron in a different room. If you get the same problem then there's possibly a wiring fault (maybe a broken/worn insulation on the wires of the iron cord ... though as it's new, I would doubt this).
Are you using an electrical extension lead to plug the iron into? If you haven't overloaded the socket with other electrical appliances it may be that the extension cable has a broken/faulty/loose wire inside that when they touch, causes the power to go off. A few years ago the power in my house used to go off on occasions whenever someone went to the fridge. The fault was traced to split insulation on one of the wires in the extension cable I was using. Whenever somebody stood on the cable it shorted out and cut the power.
To be really sure - go into a neighbours and use the iron! If the power goes off - it's the iron at fault. If not, it's probably just a small problem like worn insulation/loose/broken wire in an extension lead in your own house.
Sep 19, 2008 | Conair Compact Garment Steamer Iron
Russell Hobbs 13968 Iron Logo
186 people viewed this question
Top Russell Hobbs Irons Experts
 Mikey
Mikey
NOEL
NOEL
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
