Need to put back door handle which has come loose
SOURCE: refridgerator door handle
some there is a plastic sleve or cap you push up to get to it some you open the door and pull back on the gasket to get to hard to know without mod num
SOURCE: Door handle loose on Model GSS25WGTA
There is a cover that runs up and down the door. This cover is removed simply by using a thin screw driver and peeling it off. You will find the Bolts under this cover. BE CAREFUL not to over tighten the bolts..
Good Luck
SOURCE: Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
SOURCE: LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
SOURCE: Whirlpool conquest side by side Refrigerator model GS6SHAXMQ00
I called GE. They offered to send a repairman out and waive the service charge. The repairman came out the next morning and tightened all the "screws" which are a certain type that I have never heard of. Maybe we can go to Home Depot and get this special kind of screwdriver. It is not a hex screw driver but some other type that I don't recall the name.
