Question about Maytag MSD2756G Side by Side Refrigerator
Arking and noisey compressor startup. can smell a burning odor after restart
Have a 06 unit and today it has started emitting a burning electrical smell upon compressor restart the startup sounds strange and maybe crackling or arking..
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like a bad overload relay assy for your compressor, its attached to the side of our compressor assy if that is what making the noise heres the part number 12002784. but if its burnig and arcing enought o ruin the compressor terminals you may need a new compressor, and depending on when purchased may or may not be covered. new overload relay comes with new compressor if needed
Posted on Oct 27, 2008
My oven caused the fuze in my home to blow twice today. It is also emitting a electric burning smell. Any ideas?
Absolutely.
Do not use the oven again unit it has been replaced or repaired, as it may very well start your dwelling on fire.
The fuses are made to stop fires by blowing out.
I sounds like you may have some bare wires inside the oven, or a shorted out control.
Dec 01, 2015 | In Microwave Ovens
Brand-new window unit emits musty smell when compressor shuts off
It SHOULD NOT ... (smell in... even in WEST TEXAS).
BRAND NEW... Rush on down and get a good
NEW one.
I would suspect the condensate drip pan is plugged...
Common for AC units ..
But NEVER in "brand new"...
Get that (previously owned (my opinion)) UNIT
back from where you bought it ... Trade it in for a CLOSED BOX... and make your sales CLOWN write up why you are returning it.
Mold can be quite dangerous!!
Carnac the Magnificent
Apr 26, 2017 | Frigidaire Heating & Cooling
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
Is there anything we can do to remove the smell of burned food from the microwave? The smell has permeated the inside of the unit and emits the burned food smell whenever it is used.
I've adviced you to placed charcoal inside the unit overnight or when it is not in used.
Charcoal will absorb the upleasant odor from your microwave oven.
Thanks for using fixya...
Jan 09, 2011 | Whirlpool Microwave Ovens
Our mitsubishi split system heat pump MSZ-A 12NA is emitting an odor - swamp water smell.
Usually if you get a musty smell, the unit is short cycling. This means the compressor is coming on, then turning off for a couple minutes, then coming back on. The best way to tell if this is the issue is to turn the unit way down stand outside and see if the compressor is turning on and off. If it's staying on, let me know and we will go from there.
Sep 28, 2010 | Mitsubishi Heating & Cooling
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
Jul 28, 2008 | Sharp CV-P09FX Air Conditioner
Microwave emits a burning smell when on
there is a transformer dont use it and get it serviced
Dec 28, 2007 | KitchenAid KEHC379JSS Electric Double Oven
Electrical smell
The most common cause of electrical smell on these units is from the compressor start relay. Get behind the fridge and remove the cardboard cover at the bottom. The relay plugs onto the compressor. See if the smell is stronger there. Also listen for it to try and start the compressor. If it just humms and clicks off, the relay is probably shorted out and needs replacing. Do not let anyone put a "fit all" relay on it, some of them will work ok for a while but cause a compressor failure a few months down the road.
If the relay is ok, check the icemaker area. A burned icemaker module will sometimes give off a foul odor.
Post back if you have any questions.
Thanks/Mike
Nov 06, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Plasma TV smell?
i had the same prob and thought it would burn off. It didn't after a month. Read the comments and tried the plug direct into wall socket plus i washed off the tv surface several times. Now no smell. Not sure which action cured the problem but i'm now happy. It was so bad i had to leave a window open and at times i would gag from the smell.
Jul 20, 2007 | LG 50PX5D 50 in. Plasma HDTV
Maytag MSD2756G Side by Side Refrigerator Logo
204 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
