My pc speakers not working - Audio Players & Recorders
  • Gareth Jones Feb 22, 2012
    Thanks Brian , the problem was the suwoofer control knob . Thanks again.
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
if you dont have a motherboard disk you will need to download the sound drivers
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Posted on Feb 22, 2012
Speakers dont work
tried to hooked up a powered pc speaker at the head phone jack of the pc notebook. if you can get sound there, then the problem it could be the speaker is worn out or the amplifier circuit has a problem.
Jul 22, 2012 | Sylvania G-Netbook
I have intel pentium (R) 4 cpu 2.80GHz but its sound is not working meanz the usb port is working if we use headphones on it then headphones are working but speakers are not working i tried every type of...
If the headphone is working,
and you are connecting a compatible pc speaker to the same green port at the back panel of pc,
and if the connecting cable is not faulty,
speaker should work.
Make sure speaker is powered on
Also check the same speaker with another pc if it works.
Oct 10, 2010 | Computers & Internet
It works only one speaker !
The cable will run from the PC to the first speaker, then from the first speak to the second speaker. If the second/furthest speaker is the one that doesn't work, it is possible that the connection between the two speakers is bad. Check the cable for damage.
If the first speaker/closest speak to the PC or the one connected directly to the PC is the one not working, the problem is like your jack. Check to make sure the cable is fully seated and that the speaker jack is not loose. Run Windows Update and check for audio hardware driver updates as well.
Sep 03, 2010 | Dell A525 Computer Speakers
Dell Dimension 4700 PC Speaker No Sound
Check to make sure all cables are connected. After this you will need to click on your sound card properties and set it to 5.1. which will allow all the speakers to play.
Please note you will need to have a card that supports 5.1 sound I do not believe the stock card in the Dell supports this feature which could be the problem.
Feb 05, 2010 | Dell Dimension 4700 PC Desktop
External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
Speakers not working
Hi
Check the device manager and make sure everthing is enabled.
If everything is enable called the support guys for the speakers
Mar 25, 2009 | Acer Aspire™ T180 PC Desktop
Scratchy Sound, Major Problem
Try the speakers on another PC with good working sound. This will indicate either a speaker problem or a sound card issue.
If speakers work ok on 2nd pc, then you have a sound card issue on your pc. If speakers are still scratchy on 2nd pc.. check the metal connector end, make sure it is clean and shiny. If there is any rust or other oxidation, clean it off with a very fine grade of sand paper
Apr 28, 2008 | Logitech X-530 Computer Speakers
Speakers do not go on.
try the speakers on another PC with working sound. This will tell if the speakers have gone bad or not. If they work on a second PC, the you have a sound card or Windows volume issue on your PC.
Apr 16, 2008 | Audio Players & Recorders
Speakers
Most speakers are 'Dumb' devices that means there isn't any information exchange between them and your PC. Other than your PC providing the source sound for your speakers to play.
Some sound cards can detect that speakers or a microphone are plugged in but not what type.
Possibly your sound card on your PC is not working or you have the speakers plugged into the wrong sockets.
Jan 09, 2008 | Audio Players & Recorders
23 people viewed this question
 Grubhead
Grubhead
