Question about Maytag Dishwasher
How do I unlock the controls on a GE dishwasher, model GSD6610
Leaking around heating element posts that protrude through dishwasher body
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
www.geappliances.com/products/recall
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
Apr 21, 2014 | General Electric Adora GHDA670N Built-in...
How can i unlock my ge dishwasher.
What model GE dishwasher?
Aug 19, 2013 | GE Dishwashers
My GE Profile double oven rage will not unlock after self cleaning model # PB970SPSS. How do I unlock the oven?
If you can unplugg it, do so and leave it unplugged for atleast an hour. If you cant unplug the unit flip off the breaker for an hour and then it will reset to factory settings.
Dec 17, 2010 | GE Profile PDW9880NSS Stainless Steel...
I need to unlock my ge profile pdw9200jcc dishwasher
To unlock the dishwasher controls, press and hold the HEATED DRY pad for 3 seconds.
The light above the lock pad will turn off. To lock the dishwasher, press and hold the
HEATED DRY pad for 3 seconds. The light above the LOCK pad will turn on.
If you need a replacement manual you can get one on the link below.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-55015.PDF
Good Luck and please rate 4 thumbs up for the free answer
Sep 21, 2010 | GE Kitchen Ranges
Ge profile dishwasher will run, but door will not unlatch
sounds like a bad control module/ circuit board. go to searspartsdirect.com and see the image and part # with price. the part can be ordered shippied direct to you.if this help please send me a 4thumbs up post thanks!
Mar 02, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Ge profile dishwasher runs for hours
HI, this will occur if there is a major control fault in the timer module or, main control board. Depending on you model, you will need to replace the timer or, control board in this case. this will fix this issue
Jul 15, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
My controls are locked
If you accidentally pressed "Heated Dry" for 3 seconds and it locked your controls, just press the same button for 3 seconds and it will unlock.
Aug 23, 2008 | GE Profile PDW8400J Built-in Dishwasher
Maytag Dishwasher Logo
65 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
