Question about Husqvarna Garden
My husqvarna 172 cutting gear will not work checked the cable with spring and it was connected but seemed slack
  • pkierans Feb 20, 2012
    When you pull the lever up to start cutting the blades will not operate, the cable that operates this goes from the lever to a device like a pully and the spring attaches to this but on my mower this is too loose and nothing happens.
    Sergeant:
  • 316 Answers
Hello, don't understand what you mean by cutting gear not working,let me know,
Posted on Feb 20, 2012
  • pamabell Feb 20, 2012
    http://www.husqvarna.com/ddoc/HUSI/HUSI2...
    ,,,hello,here is the parts brake down for your CHT172 tractor, on page 17 mower deck assy. part # 152 clutch cable that shows with a spring,you can order a new cable or clean the grass off of the deck and try and see what is wrong,why it is to long or not engaging,a little pm goes a long way,,
Adjusting the carburettor springs on a mountfield sp530 to run correctly
most governor springs do have slack... they are designed to apply pressure during operation... the governor tries to run the engine wide open, the governor spring brings it back to a safe usable rpm... most small engines run well between 3200~3600 rpm's... I don't know what engine you have so I can't help more
Oct 20, 2014 | Garden
Hi. I inherited a 1998 Husqvarna 265 rx. Got new plug and new fuel and it fires ok. Wouldn't stop so I added a washer under the 'earth' screw and it now stops. Problem is poor acceleration
To set the throttle, start by slackening the cross head screw securing the cable in the handle and pull completly out, now slacked the three allen headed screws securing the handle, twist the handle to the best position for your use ( at full throttle your thumb should not be straining ) now slacken the lower cross head screw and turn the silver clamp to tention the spring underneath, when correctly adjusted the throttle trigger should spring back to the idle position readily, now re fit the cable up through the clamp, turn the cable so as it is just about to open the carb throttle spindle, lock the cross head screw and test to make sure you are getting full throttle, if not slacken the screw and turn cable a little more.
Sep 19, 2012 | Husqvarna 531004054 Throttle Wire
How do i adjust the tension on the cables which control the triple chainring [ shimano 515 ]gearing and the rear gearing? presumably there will be other adjustements to make after this is done.
The tension on a derailleur cable is determined by a spring in the derailleur itself, and is generally not adjustable. The available adjustments on the derailleur control the limits to it's travel (and in the case of the rear deraileur, the chain tension). The shift levers that you operate to change gears generally have an adjustable resistance (to keep them from sliding into another position), but this has zero effect on the tension on the cables. If you have indexing shifters there are additional adjustments. If your cables are going slack it might seem that the spring in the derailleur is too weak, but this is a lubrication issue, or you may need to replace your cables. There is a good article on derailleur adjustments at - http://www.parktool.com/repair/readhowto.asp?id=64 Good luck
Aug 12, 2010 | Cycling
Drive stopped working
There is an idler pulley inside the deck with a spring. The belt probably jumped of the idler which would result in the drive cable being slack. You can probably fix this yourself by re-routing the belt so that the idler with spring engages the belt. Depending on the condition of the belt you may have to losen all of the engine mount bolts so re-route the belt properly. I have had to take out all but ONE engine bolt (left loose) to install a belt.
If you need details on bolts / covers that need to be removed I need the whole model number to be of further asistance.
Thanks for using FixYa.
Kelly
Jun 16, 2010 | Mtd 22" White Outdoor Self Propelled High...
I have a husqvarna 172 ride-on lawnmower. Running
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Aug 02, 2009 | Garden
Husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
May 01, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Hot start lever siezed in plunger of crf 250 x carburettor
have had the same problem many times. spray carb cleaner into hole where the brass plunger is located give it a little time to let the cleaner work. put some force on the cable it may come out if not remove the cable at the other end so you can remove carb to work on it
Mar 26, 2009 | 2005 Honda CRF 250 X
Replaced throttle cable on pw50 but can't seem to get it adjusted
If I understand your problem correctly this may help. There should be a spring just a bit smaller diameter than the slide that mounts between the top of the slide and the bottom of the carb cap. No spring means no snap-back. I am assuming there are no kinks in the cable and the cable was routed correctly when installed. Lots of times if the cable is not routed properly the gas tank will "stretch" the cable when the tank is re-mounted. Route the cable properly and the problem goes away..... As far as the slack in the cable, there is a an adjusting screw on the top of the carb (where the cable ends) and an adjuster screw at the hand throttle also where the cable ends. Some bikes have an extra adjuster mid cable but I don't think yours does, (working from memory here). If none of the above work then my guess is that the parts counter handed you the wrong part.
Mar 14, 2009 | 2000 Yamaha DT 125 R
1991 Ford Escort F4EAT Won't shift into 1st unless I put into Low and even then it slips and chatters until it finally grabs then it doesnt seem to slip at all could it be gearshift position sensor or a...
Pop the hood, and you'll find a cable running left to right (near your throttle body). It also has a spring that snugs this cable so it will have no play.
A common problem with the F-4EAT in the ford escort is that over time for some reason there becomes slack in this line or the spring wears out. If you are having trouble getting into first this is usually the problem. simply adjust the length of the cable and replace the spring.
If that doesn't work... I heard something about cleaning out the accumulator (some sort of spring mechanism) as it often causes this transmission to be sluggish (or change gears very late).
cheers.
Sep 06, 2008 | Ford Escort Cars & Trucks
Garden Logo
62 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
