When i turn on my gateway ms2252 laptop it does one of 2 things the first thing is it lights up the lights and spins the fan and then makes a small sound and the lights go off and does nothing else. the second thing is that if i press the power button the lights come on and i can hear the fan spinning but the screen stays black.. my lap top does one of these 2 things i described everytime i press the power button...can you help me please??
    Top Expert:
  • Computers & ... Master
  • 12,962 Answers
Bad battery. If it does this when you are using the adapter then the issue is with the motherboard. or a bad peripheral.
Posted on Jun 24, 2017
3 Suggested Answers
  • 285 Answers
SOURCE: compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Posted on Mar 11, 2009
ButtFuzz
  • 463 Answers
SOURCE: Gateway MT6451 Does not turn on
Probably the mainboard or flaky power supply.
I'd start by replacing the power supply. Buy one you can use in a new machine, though... or "borrow" one from another machine.
I have a dell dx series, I just plugged this bad boy in, it hasn't been pluged in for 2 months. it will turn on I can hear the fan but my mouse, keyboard, or any of the other plug ins wont work, I get no...
must have taken a hit before you tried turning it on in the 2 months. dropped, or shocked electrically or someone was messing withit.
or it wasn't working before you got it. only way is to have it checked out. one thing, the fan over the heat sink(over the cpu processor chip), might not be working. take a look and if it does not spin(fan) when you power up then this will prevent pc from booting. have seen this happen before. move wires from van and check connection to motherboard. if it does not spin then take it to shop tell them what you think and they may not charge you to verify it. good luck
Aug 24, 2013 | Gateway Computers & Internet
Running windows xp on my gateway ms2252 laptop no audio driver
I would go to the Gateway site and download the driver under Customer Support.
Oct 03, 2012 | Gateway Ms2252 17" Laptop Original...
Compaq presario CQ61 is making a vibrating noise. it is constant
Two things,
1) Check if you have a CD/DVD in the disk-drive and remove it. The spinning disk is causing the vibration
2) Go to START > Control panel > PERFORMANCE AND MAINTENANCE > POWER OPTIONS >
In the middle of the dialog box, you should see a box that says "Turn off hard disks".
There you can select "After 3 minutes" or "After 5 minutes". This will turn off another spinning/vibrating thing if you have an issue with imbalance there.
3) Make sure you are not blocking the vent holes on the bottom of your laptop so air can get through and it doesn't overheat. The last spinning thing on your laptop is the cooling fan. This only comes on when it is hot. If you are doing a lot of calculations or heavy-duty computing will also make it hot but this is very rare (I guess some games can also be considered heavy-duty computing and cause overheating). If you are doing heavy-duty computing, there is nothing that can be done about he vibration of the cooling fan.
Good luck
May 06, 2011 | Computers & Internet
My Gateway M675 notebook has not been used hard or all that often. I pulled it out today, turned it on and it did not boot. The power light and the battery charging light came on, but the HD did not...
The BIOS battery may have been drained out because the only time it charges is when the laptop is powered on. Check the BIOS battery - you might need to replace it.
Jan 22, 2011 | Gateway M675 Notebook
I have a gateway NV55C03u, The fan isn't turning on or is running slowly when ever i go to play World of Warcraft (WoW). I have never had this problem running WoW before, and i would like to know if buying...
does the fan run normally when doing other things?
Does the fan make any unusual noises?
Is it dirty, or coated with dust?
Sometimes cleaning and oiling will keep you working for some time.
Dec 26, 2010 | Gateway NV55C03u Laptop
Gateway M-1624 laptop PC, is overheating. What can I do to fix the problem?
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
also buy your laptop a usb 3 fan cooling pad
Nov 24, 2010 | Gateway M-1624 Notebook
Gatweway lap top button light up, but wont turn on
I'm afraid this sounds suspiciously like a motherboard problem. It would help to know what model etc, as some Gateway & EMachine model laptops have had extended warranties due to motherboard issues, or just go to Gateway.com and research it yourself.
Jul 20, 2009 | Computers & Internet
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
Computers & Internet Logo
177 people viewed this question
David Payne
David Payne
