Question about Jenn-Air Freezer Jenn Air Clear Cube Ice Maker
Kenmore icemaker won't work
I left on vaction and turned offt the water but not the icemaker, now the icemaker won't work . I water flow at the water tap in front , any suggestions dridd@msn.com
  • Jenn-Air Master
  • 19,396 Answers
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
No water flowing to ice maker
to see if icemaker is still good pour a 1/2 cup of water into tray and wait for a day. make sure shutoff arm or switch is on or down (arm down) if it makes ice then the icemaker is ok. if it dont then hold up.
if it makes ice then either the water pressure is too low (or no water) or the water valve is bad. (to check water valve you need a volt meter).
ok back to hold up part... the icemaker actuallys controls the water valve so you can have no water but that doesnt mean the icemaker is bad. so here are the three possiblities to your problem:
ice maker
water vavle
not enough/no water
before you buy anything let me know and we can go over this again
hope this was helpful (or confusing sorry)
Apr 02, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Kenmore freezer not making ice
Pour about 1/2 cup of water into icemaker ( unless ice is already there ) . If the icemaker dumps the cubes , then the water valve is bad . If it doesn't dump , and holds the frozen cubes , replace the icemaker . Also check your coils to make sure they are clean from dust , lint , etc . Check the fill tube going to the icemaker , to make sure it isn't frozen with ice . If it is , then watervalve is still bad (leaking ) .
Aug 25, 2009 | Kenmore Freezers
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Freezers Logo
380 people viewed this question
Top Jenn-Air Freezers Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Bailey's...
Bailey's...
Are you a Jenn-Air Freezer Expert? Answer questions, earn points and help others
