Question about Maytag MLE2000 Front Load Stacked Washer / Dryer
MLE2000 front load washer
I have the Maytag Neptune stacked front load washer and dryer. This unit is 8 years old. The washing machine keeps turning itself off once a cycle has started and I have to restart it. Have restarted it 4 times until the load is done. It does it on all cycles. Sometimes the lock light goes out and the water does not drain out of the clorox dispenser. Thanks.
jilbert57@embarqmail.com
  • Fish4vets Nov 04, 2008
    I have the same problem.  My unit is 7 years old.  I bought and replaced the Wax motor part # 12002535 but the problem is the same.  I was thinking of replacing the control board located on the top of the machine but it cost about $200.  Not sure if I want to try to replacing part after part without any proper diagnosis.
  • abachewicz Jan 19, 2009
    I have the same unit (about 4 years old)--was told to replace the timer for about $175--did that but it did not solve the problem
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Posted on Dec 19, 2008
Can't Locate Strut Displacement Switch on Maytag Neptune MLE2000
there is a micro switch half way up on left strut looking from front
Feb 18, 2013 | Maytag Neptune MLG2000A Front Load Stacked...
Door lock suddenly does not function when depressing the start/stop button on my Neptune Super Stack SL3 washer-dryer. The locked light is on however. The result is that the washer will not spin or drain.
If you take off the face plate where the knobs are at or if you know how to get to the wax motor you'll find a red solid cable and if you pull this cable it will release the mechanism which is keeping the wax motor engaged
Jun 30, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Washer doesn't empty after wash cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 10, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
I need an operating manual
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's and installation manuals are available in .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Apr 20, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
My washer will not turn on, my dryer will spin but not heat
Is this a new installation, or has it been running fine and now acting up?
Apr 17, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Dryer turns but doesn't heat. How do I troubleshoot?
Likely causes are:
- broken heating element
- burned/corroded connections in heating circuit
- blown thermal fuse / limit switch
- bad thermostat
If you don't have significant of experience with electrical appliance troubleshooting & reapir, this is a difficult task.
May 08, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Replace wax motor on neptune stacked w/d
I just recently purchased a used Maytag MLE2000AYW Stacked washer/dryer. The problem I am having is that the washer unit seems to turn on, the lights go on, fills with water, but doesn't not engage in the wash or spin cylce. There also seem to be a kind of intermittent spinning sound every five seconds or so when it is in the wash cylcle. Can anybody give me some ideas to troubleshoot for?
Mar 31, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Water won't completely drain from tub. Door seal is very moldy.
Had a simular problem. In my unit the water was not visible in the drum but you could hear it when you turned the drum by hand.  The answer as told to me by the Maytag repair man:  The machine is designed to hold the water after the cycle is complete.  As he was replacing the boot seal he suggested to just leave the door open so the seal will dry out and not mold.  This has been working for the past several years.  No mold has appeared on the new boot seal.
From another source I read that the water is left in the machine for balance.
Feb 02, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Jan 27, 2009 | Neptune MLE2000A Front Load Stacked Washer...
Water wont drain all the way
I have the same problem and am trying to get it fixed. You can find good info here: http://www.applianceguru.com/
Search for the model name and number of you appliance. Good luck!
Aug 24, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag MLE2000 Front Load Stacked Washer / Dryer Logo
244 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
