Question about Nokia N95 Cellular Phone
Nokia n95 not working
After i put last software the phone work for one houre only after it stopped ( no work ) only lighting for one moment and again off and again open ...etc
what is this problem and solution
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile repair shop and have them fix it for you.
Posted on Nov 02, 2008
My nokia n95 2gb water damege now set dead and when in put cherger set heat
try sundry it for days first then couple it back it should work
Mar 13, 2011 | Nokia N95 Cellular Phone
I cannot access my last called numbers or recieved or dailled calls. and have updated the software and works, but when I backup it has the same problem again. N95
check you message settings and check weather you using phone memory or card memory and lastly check in file manager that you have a enough phone memory to memorise your last called numbers...
Feb 10, 2010 | Nokia N95 Cellular Phone
N95 got wet with sea water.No 9 do the same as " play " button
depending on how long ago it got wet.... if it was recently, take it apart and put it in a bag of uncooked rice, the phone and battery apart. if you keep it there about three days, it should work fine.
Aug 06, 2009 | Nokia N95 Cellular Phone
Nokia N95 keys wont work after being in my pocket in the rain
remove the battery and, soak the phone in 90% isoprophyl alcohol (rubbing) using a spraybottle soak your phone completely let it sit for an hour (don't worry you will not harm it) then: using a hairdryer on low gently dry your phone replace the battery and, start it this should work if it doesn't then you must diassemble the phone and use the alcohol again inside it or, return the phone for repair the alcohol can be purchased at a drug store
Apr 27, 2009 | Nokia N95 Cellular Phone
Fitted battery to nokia n95 and the phone stopped working
the battery that u ve bought its not fits the phone battery reference:
Nokia BL-6F - Batterie Li-Ion 1200 mAh
Nov 30, 2008 | Nokia N95 Cellular Phone
N95 startup problem
do not consult a technicition i have had this problem and solved it for my friend, you were trying to update your n95 firmware using nokia software updater then it said please unplug and remove battery you should never touch a mobile during an update... anyway to fix it your n95 thinks its still in a middle of the update so charge your phone for 10 minutes (DONT TURN ON) then connect up to the computer via usb to your n95 then open up software updater and press start update it it says could not find deivce keep retrying it took me 20 minutes but could last up to 1 hour then it willl recognise the phone and continue update and turn itself back on only problem is that your phone will be reset but you still keep your memory card data
post back asap dale goodwin
Jul 22, 2008 | Nokia N95 Cellular Phone
Nokia n95 wont send text messages
N95 Memory Full Problem can not be resolve by simply restarting or by changing the network setting. You must "Manual Reset" it. Just Turn Off the Phone, Press the *, Call Button, Three and ask another Person to turn on your N95 by pressing the power button. Stay pressing the Three Buttons until the phone fully boot up and ask you to enter Date and Time. After that, youre phone will go back to Factory Setting.
Good Luck,
I'm just want to Share.
Jun 26, 2008 | Nokia N95 Cellular Phone
My nokia n95 8gig camera won't come on.Please help
check d last version and install it . the new latest wont work for ur device.
May 09, 2008 | Nokia N95 Cellular Phone
Problem with n95
probably your phone get corrupted.. have your phone reformat to a lower version...
Oct 24, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
