Question about Moen Home
Moen bradbury poor water flow
Installed new moen bradbury hand held shower. Poor water flow. There is a green insert in the handle. Is this a water restrictor device? If so, can it be removed?
  • 185 Answers
SOURCE: Just installed a Moen 3867 hand held shower. There
Usually whenever you do any repairs on plumbing, you dislodge calcium from the inner surfaces of teh plumbing. Check to see if ther is a mesh filter in the inlet side of the head. and remove and clean it. otherwise you could remove it and use a vacuum yo try and remove any deposit that may be in it. If that is unsuccessful,
you can always return it, but always remember to open the fawcett and run it before installing the head.
This is an essential part of any plumbing job. Good luck
. If your local store refuse to replace it Moen will gladly do so with no problem.
They are good like that.
Posted on Mar 04, 2010
  • 299 Answers
SOURCE: flow restrictors
Remove the shower head from the arm and look inside the connector on the showerhead. You should see a plastic or metal piece that will either unscrew or need to be pulled out with needle nose pliers. Once that's been removed the flow should be improved.
Posted on Apr 20, 2010
jyackle5
  • 8197 Answers
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
Posted on May 16, 2010
SOURCE: Our Plumbing Inspector has rejected the faucet due
plumbing code varies by area, so I don't think it's an issue with the company. they do have vacuum breakers 4 sale, though.
http://www.signaturehardware.com/product598
Posted on May 24, 2010
  • 81 Answers
SOURCE: moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Posted on May 29, 2010
Moen old shower faucets
Turn off the water to the house undo the screws. Pull out the cartridge. Bring it to any plumbing place or builder supply. Hand it to them they may hand you a new one free without a word being said. This has been the way for decades now. Install the new cartridge.
Nov 29, 2013 | Moen & One Handle Tub & Shower Faucet
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
I replaced a broken Hansgrohe hand shower with a new Hansgrohe Clubmaster 3 - now have very poor water pressure - how to correct?
Hi Christieb942,
When you get a new hand shower you can sometimes get sediment on the federally mandated FLOW RESTRICTOR. Not screaming, that is ****** in cheek. To CHECK the Flow Restrictor for debris, look at the hose connection end of the hand shower. You will see an INSERTED part that is green, yellow, or white. We have to push that in there to satisfy the EPA requirement for flow. You can pull it OUT and rinse it off. Then connect your handshower and try it and see if it is improved. You will not void the warranty in any way by doing this. I hope you understand what I am telling you, but if not you can call me 800-334-0455. I wish I could answer more directly, but Big Brother has eyes.
Sep 18, 2011 | Hansgrohe Model 28525: Clubmaster Oil...
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
Moen monticello shower control, remove handle
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen fauset # 1225 Shower new cartridge and it still drips.
is it official moen 1225 ? generics can be of poor quality. turn off house water and remove cartridge. Small fingers? Put in valve and feel for debris or turn on whole house again for a few seconds to flush out valve. try another cartridge. Or try this first. take off handle and push in on stem. does drip stop. ? perhaps handle is not on right.
Apr 28, 2009 | Moen Plumbing
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Moen posi-temp valve with little pressure
no,, they are set with water savers, they only flow aprox 2.5gpm this is the top flow,, if you have it more on hot you will get less flow bings it is temp control and won't let you burn your self,, nice thigs the government does,, the only other thing you could do is go back to the old style 2 or 3 handle diverters, but we all know nobody wants them anymore, good luck
Apr 03, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Our shower has not been used for a while. Now when we turn it on
Do you have good flow if you remove the shower head, y/n if not how old is house,galvinized plumbing?? or copper plumbing. Sounds like you have a clogged valve and if so this link will be good.
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
87 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
