How can I get service manual for Yamaha RX-V850?
I can turn on the unit, no sound, if I turn the volume extremely high, I can hear the sound (very low level). The tuner looks ok
  • Randy Leonard
    Randy Leonard Jan 28, 2014
    Make sure the shorting bars are installed in the back. Download the user manual from yamaha to see what I mean. I just spent three days crawling around inside this machine.....lol....power was all ok, signals were all there yet no sound. I was ready to throw in the towel but decided to download the user manual....low and behold, I finally noticed that the shorting bars in the back were missing but MUST be installed!!!
3 Suggested Answers
satavlad
  • 405 Answers
SOURCE: My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Posted on Nov 05, 2009
SOURCE: Volume on Tv/dbs mode extremely low......volume
I have the same problem, I'm thinking that the equipment is old and I need a new one. need an answer too!!!!
Posted on Nov 06, 2009
Do I need to connect my older Fisher Turntable to a pre-amp before connecting to my Yamaha RX-V850?
No, you don't need a preamp if your turntable has a moving-magnet (MM) cartridge, it should work as-is! Happy vinyling =]
See page 27 of the manual:
Yamaha RX V850 User Manual Page 27
Aug 09, 2016 | Yamaha Rx-v850 Audio Video Receiver Black...
How to connect my lg lcd tv to yamaha rx-v850
Use the Component Out sockets (RCA sockets - Yellow , Green , Red yes 3 wires) on TV to Component In sockets on Receiver which is again 3 wires
Jun 14, 2015 | Yamaha Rx-v850 Audio Video Receiver Black...
Rx v850
Are they connected and turned on. First read the instructions they contain some amazing information.
May 04, 2014 | Yamaha Audio Players & Recorders
Yamaha rx v850 centre and rear speakers dont work
-- Are they connected and turned on. First read the instructions they contain some amazing information.
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
How do I connect the Bose Equalizer (for Bose 901 Series VI speakers) to a Yamaha RX-V850 RS? (not as a home theater) Thanks
If you get a second amp for the 901's you can have your cake and eat it in front of the TV too.
http://www.retrevo.com/support/Yamaha-RX-V850-Receivers-manual/id/320bh027/t/2/
Two solutions:
ONE: dedicated 901-RX-V850 stereo-analog-audio only:
If you want to have the Yamaha also support non-901's as the second set of Front Speakers, put the Active Eq in one of the three selectable Tape Loops. That way you can dial the 901 EQ out of the equation and select the 'normal' speakers for your Dolby Surround video experience.
Now imagine this:
TWO: 901's for the Front on a 100wpc stereo amp, your RX-V850 or a nice digital AVR driving center and rear, maybe 'normal' fronts, too
Get a nice 100wpc amp with its own volume control on eBay and slave it off the Yam. Remove the Front Pre-Main jumpers and place RCA Y-splitters in there so the pre-main connection out is maintained but shared with the Active EQ, which is in series with the 901's dedicated amp. Use the new amp's volume to match the 901's to everything else and you just have to turn it on or off to enjoy the 901's along with or instead of the 'normal' front speakers. You could even just disable them at the Yam.
Now for some boilerplate I created to get your creative juices flowing ij case you have a digital AVR in mind for the future:
Having a 901-based multichannel setup myself, I would highly recommend getting the Full Monte for video listening (below)...
In that case a separate stereo amp for the 901's would work. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and run through your speaker setup routines on the Yamaha. After levels and distances are set the Yam will be the boss of the 901's. I recommend sharing or directing any LFE with them. With 901's don't even need subwoofers but they don't hurt.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media!
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
Shuts off at high volume
Amplifiers are designed that way to prevent overloading. One reason why it would abnormally shut off is if the speakers winding are shorted out. If you smell burnt enamel from one of the speakers, then maybe a shorted speaker is the abnormality. Extremely high volume shut off is normal though, like when you turn it up, and the sound starts breaking up(distortion).
Nov 28, 2009 | Yamaha RX-V492 Receiver
Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Mar 02, 2009 | Yamaha RX-V1400 Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Open Questions:
152 people viewed this question
 Grubhead
Grubhead
