Question about Kenmore 23022 Top Load Washer
Washing Machine Dance
I just replaced my washer with a slightly used Kenmore washing machine. Everything works gret except on the spin cycle, the machine dances across the floor. I have evenly distributed the load, adjusted the feet and still the same problem. It is on a concrete floor and the older unit I had never had this problem. Any ideas ???
    President:
  • 878 Answers
Cars, does the basket lean to one side? There might be a couple of issues. The coupler that seats between the motor and trans could be wollowed out causing vibration. Another is that one of the balance springs came off or broke. I'm going to attach a photo of the springs so you can see what this looks like. You can remove the whole cabinet to check things out or tip the washer back and take a look.
Posted on Aug 24, 2006
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
Kenmore elite washer sm 9711034, washer will not go through spin cycle at end of wash cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Kenmore Washing Machines
Everything works but it does not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue. Click on the link below for the complete and detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Dec 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
Final spin cycle doesn't wring out, does not appear to be spinning, a slight burning smell.
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 08, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer fills with water but will not continue with the wash cycle. There is power to the machine because I can her an electrical humming when I try to start the cycle.
If the water in the machine empties when you move the selector to spin but does not spin, you may have a machine that uses a coupler to connect the motor to the transmission (many Kenmore models and others). When the coupler fails, and they do, then everything will work except for the agitator. If this is the case, you can see it if you flip the unit over and look.
Jan 07, 2010 | Kenmore Washing Machines
1 year old kenmore washing machine won't spin, agitator works OK and the water drains, just won't spin.
you have a bad door switch everything on a washer works fine with a bad door switch except the spin cycle
Jun 07, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Bendix WD1043 model RV washer/dryer --all cycles work except for the spin-out cycle, starts to spin but then stops and just sits there....the belt is OK, I looked.please advise further....thanks, Jack
KENMORE RV WASHING MACHINE WATER LEVEL DID NOT STOP. IT JUST KEPT GOING & OVERFLOWED. DOES THIS MEAN THE ELECTRONICS NEED REPLACING OR THE ENTIRE MACHINE.
Aug 15, 2008 | Washing Machines
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 23022 Top Load Washer Logo
187 people viewed this question
Sal De
fordexpert
yobo007
yobo007
