Question about Denon AVR-2106 Receiver
Denon AVR-687 reset - Denon AVR-2106 Receiver
2 Suggested Answers
  • 3 Answers
SOURCE: Denon AVR-687 cannot power on, no power light lit around power
Check the main power switch next to the large power button. It is a small push button. If it is pressed in and you still have no light around the power button then very likely you have a dead power supply.
Posted on Apr 30, 2010
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
How to reset denon avr 1913
Is thereany sign of power? relay click or anything?
Jun 07, 2014 | Denon AVR 1913 71 Channel 3D Home Theater...
No sound from my ja 687 amp lights show receiver is working
Need to check on the power supply to the output drivers, if there is no response on the speakers it is possible that the output replay is under protection. You need to remove power plug and leave aside for an hour before the amplifier is plugged back. If all functions show on display but there is no sound check the PREAMP output- audio out. If there is audio then the fault is with a non switching of the power amp or a power amp protection. Since these are mounted boards with little access to testing you need to be skilled to go further to probe and proceed. Also Denon might refuse to service if the amp is tampered which also can be expensive.
Oct 25, 2011 | Denon AVR-687
NO sound
the finals are burnt out.
the output transistor are blown out because they have probably been locked up in a cabinet and have not received enough air.
or if it is fairly new check your speaker connections
Dec 05, 2010 | Denon AVR-687
Apr 27, 2010 | Denon AVR-687
Hi, I'd like to use my Denon at overseas where
There should be a switch that you could set to the various voltages. Normally a round switch in one of the corners on the rear panel that you can turn with a flat screwdriver
Aug 02, 2009 | Denon AVR-687
Volume increase for no reason
Check your settings. You can set the initial turn on volume to any level. Go thru the "on screen" main menu. hope this helps
Jul 23, 2009 | Denon AVR-687
How to change the video output on denon avr 486-I have 3 devices using the component video inputs (playstation 2, xbox 360 and a dvd player) but i have an analog video output going to my tv. my devices are...
under the system setup menu go to video setup, and re assign the devices, then make sure the video output is assiggned to component as well. That should give you what you need
Jul 16, 2009 | Denon AVR-687
No sound from any source from speakers
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
May 05, 2009 | Denon AVR-687
Denon AVR-2106 Receiver Logo
42 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
