Question about Panasonic Dryers
I have a Panasonic ceiling fan w/light. The bulbs burned out(Panasonic FDS18E35/4). I replaced them with Phillips 18wPL-C, but they do not work when I turn the unit on. The fan works, but not the b
I replaced them with Phillips 18wPL-C, but they do not work when I turn the unit on. The fan works, but not the bulb. The light module is Model# FV-LP003(Panasonic)
SOURCE: How to Change light bulb (yes, really...)
Finally, we got it. As some of these solutions suggest, the trick is to hold the metal rim while turning the glass globe to the left. It took two of us, one holding the rim and the other turning, but voila, there it is.
Posted on Mar 23, 2008
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
mikedurland
  • 481 Answers
SOURCE: Kenmore Electric Dryer Series 80
it could be the light bulb socket itself or the door switch.
Posted on Aug 01, 2008
SOURCE: changing light bulbs in Hampton Bay model AC 527 Ceiling fan
I have the same fan
Only try to turn the glass cover in the opposite direction that is posted for close. You will want to do this after the light has cooled. It tends to sieze when it lense heats up.
Good Luck
Posted on Aug 23, 2008
Hunter-ceiling-fan light wont work
Make sure your contact in the socket is touching the bulb.
Mar 27, 2014 | Dryers
My Hunter fan with light kit has a problem, again. The remote control works for the fan but not for the lights. One bulb burned out. Then the remote stopped working. Replacing the burnt out bulb did not...
this sounds like the remote in the fan went out the diod will burn out and cause this issue if you go in the fan by the breaker box and see the board you will see a burnt out diod you just need to replace the remote at lowes there about 45dollars good luck
Aug 04, 2011 | Hunter Ceiling Fan Remote Receiver...
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Fan works lights dont
It's most likely that when the bulb burned out the electrical heat got to the socket causing the emergency shut down of the lights if you take of the light casing there should be a small switch next to one of the bulbs all you have to do is flick the switch, put back the casing and walla your lights should work (hopefully lol =])
Jun 06, 2009 | Hunter 20347 Ceiling Fan
CFL bulbs won't work in ceiling fan?
they should all work. The only problem might be if they are connected via dimmer. Dimmers and CFL does not work together.
Mar 08, 2009 | IBM ThinkPad R50e Notebook
Light bulbs burn out
Use bulbs specifically designed for ceiling fans - they say "ceiling fan" on the package (Home Depot, Lowes both carry). The slightest regular vibration (like a fan rotating) causes normal incandescent elements to burn out within days or weeks.
If you wired black to black, white to white and green or bare to ground, you wired it right. Sometimes there are two blacks (hots) one for the light and one for the fan, but most of the time you hook the light wiring parallel to the fan wiring unless you install a remote switch.
Feb 18, 2009 | Aloha Housewares (93645) Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Hampton Bay ceiling fan with pull chains not working
Whether there is a reset switch on this unit or not would depend on the model. If you no longer have the owners manual you should be able to get it from the hampton web site. Many fans have a thermal fuse inline that probably was blown when the bulb broke. The cheaper models do not and then I would guess you burned out the switch.
Feb 07, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hunter ceiling fan
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
1,898 people viewed this question
Top Panasonic Dryers Experts
Electro Med Services...
michael vanier
Are you a Panasonic Dryer Expert? Answer questions, earn points and help others
