Question about Westinghouse Televison & Video
ATV 3.0 and no signal appear on screen. No picture and no sound. This is our first time setting up the TV.
We do not have cable or a dish. We have a router connecting our TV to our computer which should bring Christian TV programming into our home. Everything worked perfectly with our other TV. What's going on with this one?
  • 395 Answers
SOURCE: pdp6100hd tv audio visual not working
unplug the cable box for 1 minute then plug back in and let it reboot.
Posted on Feb 03, 2008
SOURCE: Hitachi 42" plasma TV (42PD6600)
My plasma TV seems to have problems with picture immediately after turning on. At about two weeks ago, the TV lost picture after turning on the TV. It was corrected by disconnecting power then reconnecting. A switch on rear left hand side would click bringing picture ON, somehow this clicking seems to have problems being energized lately not allowing picture to come on the TV. Checked power cable and was getting 120 Volts to TV, nonetheless problem has gotten worst and TV does not show a picture? Your thoughts on my problem?
Posted on Feb 17, 2008
  • 1525 Answers
SOURCE: picture appears for 3 sec then shows no signal
HELLO MAKE SURE ALL THE CONNECTOR CABLES ARE TIGHT ON THE MAIN BOARD IF THEY ARE OK CHECK THE INVERTER BOARD FOR DRY JOINTS GOOD LUCK
SHAUN
Posted on Apr 27, 2009
  • 73 Answers
SOURCE: Picture & sound go off for 1-2 minutes, then return.
If the green light starts flashing after losing pix and audio and then becomes solid and pix and sound return.I would suspect lamp.
Posted on Jul 14, 2009
  • 120 Answers
SOURCE: Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Posted on Jul 24, 2009
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
Sep 24, 2014 | DISH Network Televison & Video
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
There is no picture on tv
1.is the tv plugged in & getting electric?
2. Does the tv show a raster,a blue screen.
3.is the tv getting an input signal , assuming that the answer to 1 &2 was yes.
4. Is your cable box plugged in.
5. are all the connections into your cable box connected
or did one fall of
6. did you pay your cable bill on time.
If your cable box is bad , the cable company should fix or replace it for free. If you or someone else unhooked the connections,say by tripping over them,the cable company will restore the connections and chatge you a service call fee.
7. do you have dish or direct tv? either of those services will loose picture if it is raining out and picture wont come back until after the storm passes.
8. if you have dish or direct tv, and a branch,a person or an animal, a bird, has fallen on the dish/direct tv antenna, it may have misalligned the dish and it will no longer recieve the satalite signal. THere is a reallignment service
available;dish network charges $95.00 unelse you have insurance,like i do,so it only cost me $15.00 I never had direct tv soi could not say, but dish net claims direct tv is more expensive
You can allign the antenna yourself ,if it is not on a steep roof. You need one person moving the antenna & another person at the tv telling him if the picture is getting better or worse. The dish box comes with a built in signal strength gague for that purpose.
enjoy considering these options and they next time you ask
please enclose all the information that you can so that we have something to go on and work with.
Oct 08, 2013 | Televison & Video
Join dish1000.2 with dish322receiver
Hi nganhoang54,
A 1000.2 dish is mainly used on HD equipment to bring in the 3 satellites required. For a 322, the best choice of dish would be a Dish 500.
To hookup a 1000.2 dish, you would need to point the dish, and run the line into a Diplexor. From the Diplexor side with one connection, run another cable into the single connection of another Diplexor, and from there one cable into a splitter for the Sat In connections. Take the TV2 Home Distribution cable and put it into the other port on the Diplexor, and connect TV2 from the open port on your first Diplexor.
Let me know if you have any other questions!
Tommy Faust
DISH Social Media Representative
Apr 01, 2012 | DISH Network 322 DTV Receiver
Audio problems - great picture -fuzzy sound
yes..that would make sense..the cable is getting dried out, and has less conductivity when it's hot or warm..that's not unusual
Feb 29, 2008 | Sony KP-57WV600 57" Rear Projection...
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
I have a blue screen with a no signal on my tv with dish network how do i fix this
Hi. This is Phil with DISH Network. Sorry to hear that you are having an issue with the video, lets get that fixed. There are some thing we want to check first. Let's first make sure that both the TV, receiver, and everything in between, are powered on. Then we want to find out which channel your TV is on, this can be done by turning the TV off then back on again. If your TV is connected by a coax cable, for receivers with a TV1 output on the back panel: Tune TV to channel 3 or channel 4 so that picture appears. For receivers with a Home Distribution output on the back panel (the TV without the receiver by it, or TV2) tune TV to channel 62 or 75. If non-coax, cycle through TV inputs until picture appears. These steps usually fix that issue; if they don't then check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure. If the issue is only on one receiver, unplug the receiver for 10 seconds and plug back in, wait for the receiver to turn on by itself, usually withing 5 mins, and the picture should come in after that. If you have any follow up questions let me know.
Additional info can be found here:
http://www.dishnetwork.com/SupportSection/bbs-screen
Dec 18, 2010 | DISH Network 322 DTV Receiver
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
I keep getting an error message when i set my router up
The LAN cable maybe faulty, try a different LAN cable.
Jan 04, 2010 | Linksys WRT120N Router
Televison & Video Logo
217 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
