Question about Canon MP610 Photo All-In-One Printer
Where does the ink cartridge go?
Lost the manual. need to replace cartridge. where does it go?
    Scholar:
  • 181 Answers
U just have to ON the printer.
and then just lift the printer cover and the cartridge carriage will move automatically and will stop at the position where u can replace the cartridges.u just have to insert the cartridges in proper place as the old cartridges r already inserted.do not remove all the cartridges together just remove 1 and insert 1.
thanks.
Posted on Nov 14, 2008
I need to replace the ink cartridge but do not know how..lost my manual
You have not listed the model of printer, however in most standard inkjet printers, once you open the lid of the printer, the print head carriage automatically moves into view and you can just pull out the color that needs to be replaced and put the new cartridge. As always, read the directions that come with the new ink cartridge, incase there is any packing material that needs to be removed from the new cartridge before installation.
Mar 02, 2011 | Computers & Internet
How do i change black ink cartridge (lost manual)
All printers are different but there is either a button on the side or front or you just lift cover. The printer cartridges will appear. You may have a lid over the ink jet cartridges. Unlatch it and replace cartridge. Laser cartridges you usually just pull evenly and they will come out.
Dec 31, 2010 | Office Equipment & Supplies
Lost my manual, need to change the ink cartridge, help
  1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
  2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Dont' Know Where Printer Cartridges Go In Brother MFC Printer
Here is the manual:
MFC240c Manual
See page 93 for ink cartridge replacement.
Thanks for using Fixya.
Jun 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Need to know how to change ink cartridges, need manual
Both of your answers are at the below link.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=257&modelid=15600#DownloadDetailAct
hope this helps
Apr 13, 2009 | Canon iP3500 Photo Printer
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Changing cartridges
Did you get the answer for how to replace the ink cartridge, because I don't have a manual myself and I can't even figure out where the ink cartridge is located?
Dec 11, 2007 | Office Equipment & Supplies
Canon MP610 Photo All-In-One Printer Logo
1,705 people viewed this question
old marine
old marine
