Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Turns on, buzzes a couple of times and shuts off
I have had my camera about a year with no problems. I took pictures the other day and all was well. I left it on the dock charger and when I next tried to turn it on, it turned on for a few seconds, buzzed a couple of times and shut off. I can view the pictures, but when I try to turn it on to take pictures, it buzzes and shuts itself off.
I have an EX Z77 same problem. Camera was turned on while in your pocket, left a dead spot in the motor, must replace the lens assembly.
Posted on Nov 02, 2008
My Olympus Fe-46 digital camera taking blurry pictures and buzzing when I turn it off?
this is a common problem with htc m7 & m8 they use a focus motor and get damage from motorcycle vibration or high shocks. i had the same problem on my m7 and m8, i took the phone to the supplier and i got new one instead.
now am using different phone when riding
Oct 27, 2017 | Olympus FE-46 Digital Camera
My camera turns on but it cannot take picture, I don't know why? the last time I took a picture the screen just went black and now it just been like that .
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 30, 2011 | FUJIFILM A170 Digital Camera
Picture error
Looks more like a problem with the card - try a replacement card.
Jun 22, 2017 | Cameras
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Camera lense comes out camera makes a buzzing sound then turns off
Have had this problem too. Took it to camera shop who referred me to repairer (email f16_camera_service@ourbrisbane.com) located north of Brisbane. Fixed the lens by refurbishment of lens. Cost was reasonable & tiem about 14 days. I was very happy.
Apr 02, 2009 | Pentax Optio S7 Digital Camera
Turns on. Lens zooms in and out, gives me "Zoom Error", shuts off
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Olympus SP-500 UZ Digital Camera
Casio Exilim turns on buzzes and then turns off
sorry to hear you are having this issue. well the problem is your lens. the internal shutters have locked up and are stuck shut the lens needs replacement. repair run any where from 75.00 and up in most cases.i repair these all of the time.let me know if i can help out any further.
Oct 28, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My Camera
That is not a good thing, try and take it back where you Purchased it, the Memory might just need to be reset, and that should do it,but let the Dealer do it, just in case..
Happy Holidays
Bobby
Dec 08, 2007 | Casio Exilim EX-Z57 Digital Camera
Camera turns on and then turns off.
It seems the camera has a lens problem. Probably one of the lens gear is broken or defective. When you try to shoot the lens moves to focus and jams in the middle of the focus so shutter will not release becasue it is not focused yet. There are couple of gears in the gear chain of the lens and it is plastic. the volume of pictures you took might have caused one of the gear to wear down. The solution is to rebuild or replace lens assy. and the cost may be around $100 in US.
Mar 20, 2007 | Fuji FinePix A330 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
135 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
