Question about Mitsubishi VS-45609 TV
My Father's TV
His Mitsubishi WS-55909 Projection TV just started to show a double red and green image. I thought it was the cables or the AT&T HD DVR Box but I connected the cable directly to the TV and it still showed the distorted image. Even tried changing the AT&T box. Please advise.
  • wookie300 Oct 26, 2008
    Thanks for the quick response!
    Genius:
  • 1,139 Answers
Hello wookie300,
This sounds like a convergence problem. The convergence amplifiers in these projection TV tend to malfunction and cause this problem. Here is a way of dealing with this if you choose to repair this problem yourself.
I posted this earlier but it applies in your case:
The problem is your Convergence Amplifiers, they are usually marked with a STK392-110. You will have to also change out the fusable links connected to the STK392-110s. Desolder the pins and unscrew the ICs and remove both of them. Then desolder the fusable liks and replace them with the new ones, then insert the new ICs and solder them in (being careful not to create solder bridges). Then you will have to perform the convergence on your TV, Try to use Auto-Convergence to do this.
The STK392-110 look like two flat 6 sides rectangular boxes with screw holes on each side and they are attached to a large metal heat sink.
I hope this helps,
Shuttle83
Posted on Oct 26, 2008
  • 899 Answers
This is the conversion chips , and pbably some resistors as well this is a common repair for projection tv's
you will need to call your local repair shop to get it fixed , it will cost about $400 to get the repair done
sorry about your dads tv ,
electech
Mitsubishi TV WS-55909 only has 1 HD component imput spot; I have 2 HD devices?
look on the internet for a hub like usb ones the computers use.
Nov 29, 2012 | Televison & Video
Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a ws-a65 tried to install 1080 hd quality through At&t u-verse missing green and red color only shows yellows and blues help!!!
im just going to assume you have it hooked up wrong, call a TV person and they can come look at it, its really hard to do this kind of thing over the internet
Oct 08, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
Apr 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi VS-45609 TV Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
