Question about Food Mixers
Mixer won't run
It ran a week ago, but seemed tired. Today it won't run at all. No noises, no clicks, no nothing. brushes are good.
5 Suggested Answers
advacak
  • 125 Answers
SOURCE: kitchen aid mixer
take off the chrome ring around the rotator. remove the screws that were hiding under it. pull off the rotator and replace the "O" ring on the shaft.
Posted on Mar 09, 2009
  • 11800 Answers
SOURCE: I have a Sybo 20
The motor inside it (the primary coiling to be exact) just failed - it happens. There is nothing you can do that would cost less than the price of a new one so just junk it and buy a new one.
Posted on May 06, 2011
  • 405 Answers
SOURCE: The mixer simply doesn't turn
HI.Let me jusk ask if yiou also tried to connet to another socket.Let me just clarify that the motor itself did not work /rotate as well.Prior to that situation,have you tried to mix more than what is the capacity of your mixer.If possible motor was overworked/that's why its coil was burnt.There. are possibilities then. First might be that the mixers terminals inside will no longer engaged properly that's why it opens the circuit.Second the motor isn't working because the rotor and armatures coil was burnt because it runs beyond its maximum wattage capacity that's why it draws much current beyond the rotors coil capacity.Did you mixed something heavy.the motor works heavier the last time you used the unit?
Posted on Jul 23, 2011
  • 153 Answers
SOURCE: my mixer worked fine, I took it apart for a really
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model. Pay attention to the Motor Brushes, making sure
they are maiking contact with the Motor after re-assembly.
Posted on Aug 15, 2011
Hobart k45 won't run
the K45 was introduced in 1962 and ran until 1978 when the K45SS was introduced. You have an open circuit inside, you need to open the machine from the rear and look to the power cord connections. make sure that the wires are connected and none are floating loose. the next step would be to replace the speed control switch. then check your carbon brushes if either one of the brushes are down to the nubs then it would cause a short when you turned it on, if that is the case then be glad that you have breakers and not fuses because you would have fried your motor. the speed control switch has no power attached to it. ifg the problem still exist after checking power cord, speed control plate and brushes then you have a fried armature or stator either can short the system if they have a burned wire inside especially the stator.
let us know how you fare on this after you check out the first easy steps, we can help with the harder fix also.
Mar 23, 2013 | Food Mixers
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid stand mixer ksm90wswh how to install motor brushes/spring. Took out by mistake. Is there a only one way to put them back in?
Hi GOTWEIMS. Yes there is only one way to reinstall your brushes and that is so they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below:
If you've turned a brush 90 degrees too much, it won’t seat properly and you’ll get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> then enter the visitor type “Consumer” and the 6 character model number, in your case use KSM90P, in the Model Number box. Select one the files listed for your model that appears under Parts List (16): KSM90PSWH0.pdf (354.08 KB) and save that file to your PC (check to see it this matches your mixer model).
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder that includes #18, 20, 21, 22, 23, and 31 which is the brush holder and brush & Spring assembly respectively. This illustration along with my initial reply regarding the orientation of the brushes should allow you to reinstall your brushes with confidence. Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Jul 14, 2010 | KitchenAid KSM103 Professional 5 Series...
Someone else took out the brushes.
Hi JUDYZ0214. I don’t know if anyone has answered your question yet, so let me give it a try. To answer you basic question, if you “put the brushes in wrong or upside down”, nothing drastic will happen. The brushes need to be installed so that they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
Click on Customer Care>Locate Manuals & Guides> then enter the visitor type “Consumer” and the 6 character model number, in your case use KSM150, in the Model Number box. Select one the files listed for your model that appears under Parts List (61): KSM150PSWH0.pdf (773.44 KB) and save that file to your PC. Check to verify this matches your mixer model.
Turn to pages 8 & 9, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #21, 22, 23, 24, 25 & 26, and Illus. No. 19, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Jun 16, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My k5ss mixer will not start ,I remove the 2 screw on each side of the head, i put them back and now it wont start
Hi DENAULTR, I hate it when that happens. Those two “screws”’ are your mixer’s electric motor brushes. The slotted black threaded plastic parts are just the Brush Holder Caps and are the protective covers to the brush holder assemblies. They allow access to the brushes when they need to be replaced without having to take the whole mixer head apart.
From what you’ve described, I suspect that one or both of the brushes is (are) not seated properly when you reinstalled them. The brushes need to be installed so that they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below:
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the part names and numbers. Locate Illus No 47, Brush holder assembly that includes Illus. Nos. #28, 32, 33, 34, & 46, and Illus. No. 29, Brush & Spring assembly respectively.
Feb 26, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I have a classic k45sswh kitchen aid mixer. I removed back cover and replaced and now it does not start.Then removed brushes and must have put them incorrect but still it don't start. I notice a angle on...
Hi TRADESGIRLS, you are correct, the brushes have to seat correctly on the armature’s commutator or you won’t get any ‘juice. Unfortunately, the ‘screws’ on the sides of the mixer are just the Brush Holder Caps (brush cover), which allow you access to the brush holder assembly and has nothing to do with ‘adjusting’ the brushes. From what done already, still I suspect that one or both of the brushes is (are) not seated properly.
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the first file K45SSWH0.pdf (341.41 KB) listed under Parts List (1) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
Feb 03, 2010 | KitchenAid K45SS Classic Stand Mixer
My son thought the big screws on my kitchenaid mixer were menat to be unscrewed. He was surpirsed when a spring and something else popped out. He replaced the parts but now the mixer doesn't work. HELP
Hi, abarhum. I hate it when that happens. Your son must be a future electrician, because what he ‘discovered’ was your mixer’s electric motor’s brushes. It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. Do you know if he removed them both, or just one?
I'd suggest removing them again and making sure the brushes are facing in the right direction to contact the armature’s commutator. The concave contact face of the brush should be resting completely on the commutator. If your son turned it 90 degrees too much when he put it back together for you, it won’t' seat properly and the motor doesn’t get any juice.
It might be helpful to have your Parts List Manual on hand when you do this. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P, and select the last file listed under Parts List (4), KSM50PWH2.pdf (354.62 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on Illus. No. 47 and 29, which is the brush holder and brush & Spring assembly.
Don’t be too hard on your son… I can remember doing something very similar when I was young and became an engineer… J
Good luck, I hope this helps. Howard, Burke, VA\
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchenaid mixer motor makes loud grinding, squeaking noise.
lgardash, Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. (Within a week of her first using it, she contacted KA Customer Care and the only 'care' they offered was an explanation that the new KA Pro Mixer gears are all metal and to expect it to be louder than previous models that used a plastic gear (to fail). Well, there's an acceptable level of noise, and an unacceptable level (you don't need to be a mechanical engineer to know when something doesn't sound right) and it seems that my wife's new mixer's operating noise level was always unacceptable. It finally 'died' this past October.) OK I've vented enough on KA... now what might be your problem(s)?
It could be as simple as thorough normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding/squeaky noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure (after our mixers increasing noisiness, the bevel gear broke and the mixer 'froze').
If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
I hope this helps, and good luck! - Howard, Burke, VA
Oct 13, 2009 | KitchenAid KP2671 Professional 6 Series...
Mixer quit working
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
Sep 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
