Question about Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
What's your problem?brush won,t run
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Won't pull in dirt
you need to change belt on brush and also check for locked up bearings on brush roller and or debris lodged between brush and guard dislodge if need be or replace bearings on brush roller if they are bad
Jul 24, 2012 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Brush will not rotate but still has suction
Sorry to hear you're having difficulties with your DC14. Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you have the brush control set to 'Hard floors'.
However, if you find the brushbar won't rotate when you've reclined the cleaner into the vacuuming position, and have the brush control set to 'Carpets', it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Aug 17, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Zip brush won't spin and I can't figure out how to fix
did you check to make sure theres no clog in the hose since its powered by air?
Aug 09, 2011 | Kirby G4 Bagged Upright Vacuum
Power light on but motor won't run. where do i
the motor carbon brushes need replacing which is a most difficult job to get the cleaner disassembled. Brushes are easy to fit if You have replaced carbon brushes in other appliances etc..
Getting to the brushes in the Kirby is very difficult...
Lee in Australia
Jul 28, 2011 | Kirby Generation 3 Bagged Upright Vacuum
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush wont turn belt not broken no sure how to get to shaft to see if it is turning
Sorry to hear you're having difficulties with your DC07. If the brushbar in your cleaner doesn't seem to be rotating, please check you have the brush control set to 'Carpets', as it won't rotate when set to 'Hard floors', or if the cleaner is standing in the upright position.
If the brush control is set correctly and the brushbar still won't turn, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Jul 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Dyson DC18 all floors Bagless Upright Cyclonic Vacuum Logo
61 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
