Question about Black & Decker Garden
Neuton cordless hedge trimmer may need new motor. the blade does not go back and forth
Primary gear on motor shaft may be stripped, no source for replacement known. I have the same problem motor runs but blades do not move.
Posted on May 06, 2013
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
boscia
  • 163 Answers
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
  • 5 Answers
SOURCE: Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Posted on Apr 15, 2009
  • 634 Answers
SOURCE: My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Posted on Jul 09, 2009
  • 154 Answers
SOURCE: Craftsman 22 in. Electric Hedge Trimmer- blade stopped moving
oil them or loosen bolts and try
Posted on Aug 03, 2009
B&D Hedge Trimmer (HT33) was working yesterday but not today. Motor sounds fine & the blades move back & forth ... just not cutting any foliage ... any ideas?
Mechanical issue. Make sure that the screw that holds the moving blades up against the non moving blade is adjusted properly. If loose, the blades will not be close together during the cutting stroke and no cutting will ensue.
Jul 05, 2015 | Garden
Neuton cordless hedge trimmer sounds "rattly" and the blade doesn't go back and forth. the battery is good. could it be the motor?
Sounds like a problem I had, and it was the primary gear on the motor was stripped. So far no luck at finding the gear, but to replace the trimmer without battery would probably be cheaper.
Feb 19, 2012 | Nike Neuton CE 52 14Inch 24Volt Cordless...
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
Think we need new blades for our cordless hedge trimmer. Where can I get them??/
Try the place where you made your purchase. If they don't have them in stock...Maybe they can order the correct blades for you. If they are not a Black and Decker dealer. Try on Line at their website.
Oct 06, 2010 | Black & Decker Hedge Hog Cordless Hedge...
My hedge trimmer Mod# HT-19 blade stopped working with the back and forth action. It appears that the bottom plate rusted and wore through. Is this a fixable problem that I can do myself? Do they have a...
Not for me to be a know all,but it is so important to clean and spray oil on these blades every time after use,but to new blades,who did you buy it from? the store EG Focus,Homebase,or others will all have a listed supplier,for spares repairs,but check out the price first,also check out the lowest price for a new one,rgds
Sep 08, 2010 | Homelite Expand-It Hedge Trimmer...
Blades not moving on ss24 weedeater
I just disassembled a SS24 hedge trimmer that had the same problem of the blades not moving. The problem is that there are 2 or 3 teeth on the helical gear that are missing. Consequently, the small gear on the motor shaft cannot continuously engage the gear that moves the blades back and forth.
May 27, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Engine runs but the trimmer blades wont engage
on the back of the trimmer there is a plat take it off and see if the cam is working around and around
Jun 27, 2009 | Poulan WeedEater Hedge Trimmer 25cc Engine
Electic trimmer
You're going to take off like 20 screws including the ones that hold the handle and the hood at the base of the blade. You open it like a clamshell. There is a black plastic cover at the very bottom that covers the gear wheels (one tiny wheel that comes from the motor and a large wheel that actually moves both blades back and forth). The black plastic cover is no attached with screws. You just remove it so you can get to the gears. Now you oil and manipulate the large gear wheel until it comes loose and you can see the blades move back and forth. Put the whole thing back together and you are ready to go!
Jun 12, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Garden Logo
200 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
