Question about Nikon Speedlight SB-800 TTL Flash
Stuck in AF-ILL ONLY mode
In attempting to set up my NIKON SB 800 in command mode(controlled by the camera) it's now stuck in AF-ILL ONLY mode, or so it says on the screen. I reset, the camera, but can't reset the flash, took out batteries, held SEL button, then four empty boxes show up, then AF-ILL ONLY - AND it won't flash, not even if you hit the manual red flash button.
  • Mark Manta Feb 22, 2012
    Thanks. I think it was malfunctioning due to a low battery - I think. I reset after putting new batteries in.
    Genius:
  • 1,212 Answers
Is the flash still on the camera when you do this? If so, check your camera settings as well as the camera may be over-riding you.
If the flash is not on the camera, some of the settings for custom settings can only be changed with it on the camera via camera commands.
If you do not have the manuals, you can get them here:
http://www.nikonusa.com/pdf/manuals/Speedlights/SB-800.pdf
http://www.nikonusa.com/pdf/SB800_techniques.pdf
Posted on Feb 20, 2012
5 Suggested Answers
bearydude
  • 62 Answers
SOURCE: Nikon speedlight sb-800
THE PROBELM COULD BE IN MAIN BOARD OR THE BATTERY CONATCTS NEED ADJUSTING
Posted on Nov 29, 2008
SOURCE: I have sb 900 flash and also sb 800 then how i
what is that
Posted on Jul 10, 2009
  • 14 Answers
SOURCE: SB 800 Speedlight AF red lamp not function
The problem is probably caused by a fault in the main power circuit board, if the red light doesn't come on then you also probably won't hear the high pitched noise as the capacitor charges. Will be expensive to repair as you will need a new circuit board.
Posted on Sep 04, 2009
  • 24 Answers
SOURCE: Nikon SB-800 flash won't rotate any more
Your flash needs to be opened.There is a small pin which must have got stuck. In SB 800 we need to open both upper and lower portions of the flash. If you are good at opening gadgets, just try with proper tools. Careful not to touch the main Condenser terminals. If you are in India, I can help you out. 09341932677
Posted on Sep 07, 2009
What setting should the camera be on for an
That depends on the flash. If it's CLS-compatible (Nikon SB-400, SB-600, SB-800, and SB-900) you can use it in any exposure mode (except flash off, of course). The easiest flash mode is Auto-TTL, though some of the other modes will give you better control under certain situations.
If it's not CLS-compatible, then you'll have to take it off Auto-TTL. If the flash has a sensor, you can let the flash control itself (assuming it's at the same distance from the subject as the camera). Otherwise you'll have to go manual.
May 12, 2010 | Nikon D60 Digital Camera with 18-55mm lens
D90-Sb600 help
The on-camera flash has to flash if you want it to be in commander mode. That's how it sends commands to slave flashes. Set to "--", that's all it does, the flash will not affect the picture.
If you want to operate remote flashes without any flash from the camera, you'll need to invest in a third-party wireless commander and triggers.
Apr 03, 2010 | Nikon Speedlight SB-600 TTL Flash
I have a new D3000 and a nikon SB-600 flash. I
From the Nikon site, do you have one of these flash units.
Support for the Nikon Creative Lighting System when using SB-900, SB-600, or SB-400 Speedlights, or the SU-800 Wireless Speedlight Commander
If so You set the flash mode to "comander" the pop up flash must be UP
This Video by Nikon shows how but you will have to read the manual to get a full description go to the flash section http://www.nikondigitutor.com/eng/d300s/index.html
Then look at them all :)
Jan 21, 2010 | Nikon D3000 Digital Camera
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Intermentant --3.0 exopsure. information panel on
there is botton inthe camera BLK from there you can set it or +\ _ botton
Oct 16, 2009 | Nikon Speedlight SB-600 TTL Flash
I want to know how to use the 952AF/Nik with the nikon d200 using multi flash units with the commander mode set to channel 1
The vivtar 952AF flash is not compatible with the D200 in commander mode. Only the Nikon SB600, SB-800, SB-900 will work with that camera wirelessly.
Oct 11, 2009 | Cameras
Nikon SC-29 REMOTE CORD
Hi Kathy,
Are you ready?
1. Make sure the Nikon SC-29's Red Panel's Lock Switch is set to the Left. Pointing at Left Black Screw.
2. Connect the Nikon SC-29's (Red Panel) to your camera's Hotshoe by pushing it as far as it goes.
3. Turn Lock Switch to the Right (turn CW). This locks down to camera.
4. Make sure Nikon SC-29 (other ends) AF-ILL is set to OFF.
5. Make sure your Nikon SB-800's Lock Switch is set to the left side.
6. Attach your Nikon SB-800 into this Hotshoe.
7. Switch the Lock Switch on flash to the right.
8. When you wants to AF from flash, set AF-ILL to "OFF"
9. For the best results, set AF-ILL to "ON".
I teaches, do repairs, services and modifications on all photographic equipments.
I hope they are helpful to you as well as for any Nikon Photographers using the Nikon SC-29 Cable.
Mine has Autofocus, ITTL, Slave and Wireless Radio Remote Flash.
Truly,
atdlee@netzero.com
Jan 31, 2009 | Cameras
TTL Multi-Flash Sync Cord SC-27
YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
AND SHOOT THE FLASHES IN SETTING 4A
NO CORDS NEEDED THEN .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
Command mode to fire Speedlight SB-600 remotely from Nikon D40x
Sorry, the D40x does not have a commander mode. You'll need the SB-800 or SB-900 flash or the SU-800 commander. Alternatively, you can use the SC-28 sync cable.
Jul 27, 2008 | Nikon Cameras
Settings for sb-800 to control external sb-600
set the SB-800 as the commander and SB-600 as the slave. Press and hold the mode button to open up the menu and select the options.
Mar 25, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
300 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
