Question about HP Pavilion 7845 PC Desktop
Video plug bad
Video plug on board is broke, can I just add a video card?
  • 94 Answers
If you can disable the onboard video; 99% yes.
define 'broke' if the pins are simply bent; they can possibly be straightened.
Posted on Feb 20, 2012
My screen turns white and freezes.
Sites blocked or incompatible. Screen freeze may be video card to includ video on the mother board. I had bad video on mother board. Screen freeze very frustrating. Couldn't figure the problem. Finally broke down and tried a new video card. Fixed, and upgraded.
Mar 18, 2015 | Dell Inspiron 560 Desktop Computer
There is no display
Generally if there is no display, either your monitor is bad (try another one) or your video card is bad. If it's an integrated video card, you can install an add-on card. If the add-on card works, consider yourself lucky. If it doesn't, your motherboard is bad.
May 02, 2011 | Intel Server Chassis SR2300 and Server...
When my computer is plugged in the monitor shuts off, but I plugged my old computer in and it works fine. What could this be
This sounds like it may be a problem with your video card. Is this on-board video or an add-on card? If it's on-board try adding another card to it (be sure to disable on-board in the BIOS and switch the default output to the correct setting if applicable). If that works then you're golden. Good luck.
Apr 06, 2011 | Dell OptiPlex GX620 (GX620P434MAR12) PC...
My computer will not boot up completly. The montior has power and the so does the mouse. I pulled the video card and plugged the monitor right into the on board plug. Nothing. The monitor works because I...
Sound like you have a hardware conflict,did you try to add new hardware?go back to working setup if you you added video board make sure you disable on board video in cmos,if you are going back to original setup remove all memory chips when you power up should hear beeping,power down reinstall memory you should boot ok
Jan 07, 2011 | Biostar M7NCG-400 Motherboard
I just bought my 875WP1-E and hooked the monitor up to the onboard video port and when I power up the computer the monitor just says "no signal." What's up?
This is due to your system is not switched ON or not properly configured. Follow the below steps will resolve your problem.
1st Step: Have you hear any beep sounds? If yes insert the memory modules properly.
2nd Step: check whether the keyboard lights are flashing while switch on the system. if no, check the SMPS or SMPS connections.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 20, 2010 | Intel Server Board S875WP1-E Motherboard
I have a HP Proliant ML110 G3 server that will not produce a video display output. I'm plugged into the onboard graghics slot. There are two slots for add on graghics cards, 1 - PCI-E x4 and 1 - PCI-E x16,...
Do you have any other PCI cards connected to the server board? If so, make sure they are seated fully in the slot. If they are, try removing all of them and try your server again. A lot of time bad PCI or faulty seated PCI cards will cause your system not to display an image. If you remove the cards and still no video, you may have a bad video port - try a known good PCI video card for testing. If this does not work, you will need a new server board.
Good Luck
C2Solutions
Jan 05, 2010 | HP ProLiant ML110 G3 Server
My biostar g31 -m7 te motherboard does not boot when i try to add a msi rx800 pcie video card,,sometimes i get a overclock fail message after i remove the card and reboot,,,how do i get this card to work...
Turn the computer off.
Remove the PCI-E video-card.
Boot the computer.
Press DEL to "enter BIOS setup".
Disable the "onboard video" adapter,
or set the highest video-priority to be the PCI-E slot.
Save settings, but do not "exit" from BIOS setup.
Install the PCI-E video-card.
Disconnect the video-cable from the onboard VGA-port,
and connect the video-cable to the new video-card.
Turn the computer on, and the video-output through the new video-card should be displayed on your monitor.
Nov 05, 2009 | Biostar G31-M7 TE Motherboard
3 beeps when start the computer, no live screen
This is either memory or video related. If the video is built into the motherboard, just add a video card to one of the slots and check it out. If you have more than one stick of memory, pull one out and then the other to test each stick. Also make sure both the video card and the memory modules are seated properly; just remove them and put them back in again.
Thanks and please don't forget to give this a thumbs up rating.
Apr 25, 2009 | Intel Desktop Board D850MD Motherboard
Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Jan 17, 2009 | Dell 828FI 15" CRT Monitor
No Video
Hi Keith, the Intel D845GVAD2 board uses an integrated graphics card for video & also uses your system memory to function.
Suggest, you remove the system memory & clean the contacts with alcohol. (Allow time for the alcohol to dry). Blow the memory slots out with canned air to remove any dust build up. Reseat your memory & boot the system. (No display)?
From your description it sounds like the integrated graphics controller may be bad. The only way to test this would be to add a PCI video card to the system.
The board’s bios uses auto detect. If you add a PCI graphics card to the system the bios should auto detect the PCI video card & load display.
There is a chance that the controller is too damaged & the bios will not see the PCI graphics add in card. In this case the board would be considered bad. If you have a local computer shop or know of someone who may (have a known to be good) PCI video card, you can ask to borrow it & test your system for video display.
Here is a link to an inexpensive PCI card:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2174312&CatId=695
Intel's web site, downloads for the board D845GVAD2:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=898&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Good luck Keith!
Mike
Nov 30, 2008 | Intel Desktop Board D845GVAD2 Motherboard
HP Pavilion 7845  PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
