Question about Ovens
Westpoint electric blanket has an "E6" error code.
My queen sized Westpoint electric blanket has an error code of E6 on either of the 2 controllers when plugged into the right side of the blanket. Both function properly when plugged into the left side so I believe the controllers are OK and the problem is in the blanket wiring. What does the E6 code mean and how can the problem be repaired? The blanket is two years old and probably out of warante.
SOURCE: E6 F2 Error Code
How do I order it from them? Am I ordering the instructions from them?
Posted on Jan 02, 2008
bestdarngood
  • 3037 Answers
SOURCE: oven gives code E6 F2 on panel
This button would only be on the outer control panel. Whatever button you press to stop the timer would be considered the cancel. I am a little confused, were you able to stop this error now or is it still coming up with this error? If I may suggest, perhaps you may want to rewire the loose connections. Please let me know what other questions you may have and what situation with this problem is and I would be more than happy to help you with anything else you may need.
Posted on May 24, 2008
  • 30 Answers
SOURCE: Kenmore electric built-in oven model 911.47702201
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. Good luck!!!
Posted on Nov 08, 2009
SOURCE: I have a Whirlpool RBD305PDB8 Electric double oven
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel
Oven repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Posted on Jan 26, 2011
KevinWhite
  • 1902 Answers
SOURCE: received E6 and F2 code. repair man replaced the
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Mar 15, 2011
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
Rbd245pdt12 error code e6 &f2
This oven uses control board part number 8302967. E6 F2 is due to a failure in the control board. This board is no longer available from Whirlpool. It can be rebuild at www.fixyourboar.com with a 2 year warranty.
Apr 01, 2012 | Whirlpool RBD305PD Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Error code e6 f2
Sep 19, 2010 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
F2 error code
F2 E6 says this:
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven gives code E6 F2 on panel
The problem in our oven has cleared by itself. I did see the E6 F2 error message but for now, it's working fine. Considering the customer service was only able to help to the extent of reading the error code sheet the same as I was (the sheet is behind the touch pad) and seeing how limited the solutions were, we don't think we'll be buying another Whirlpool. I was pretty insulted when the girl a customer quality called to offer me part #8300453 at half cost of $164 providing I have a service guy look at the stove and call in the part. On top of that, the warrenty is 90 days and the part is on back order. Why would the part be on back order? A) they either did not make an ample supply for inventory, B) there are many ovens needing this part. For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me someone was sleeping with a cigar in their mouth in Quality Control. Or, learning what that meant.
Enjoy the day!
Robert
Dec 10, 2007 | Whirlpool GBD277PD Electric Double Oven
Ovens Logo
349 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
