Question about MSI Wind UmNotebook
Webcam nu porneste
Nu merge web camera
1st You download Webcam Driver.
web camera After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Other Companies Camera Drivers for Windows XP Vista Windows 7
Mar 20, 2014 | A4tech PK-7ma Flexi Webcam
Nu porneste windowsul dupa instalare care este cauza
E destul de generica descrierea ta...fi mai exact..ce configuratie are calculatorul tau pt inceput?cauzele pot fi multiple
Nov 28, 2012 | Computers & Internet
Dryer turns off immediatly after starting.
TERMOSTATUL INTRERUPE DIN CAUZA SCURT REZISTENTA SAU NU PORNESTE VENTILATOR.
Mar 18, 2011 | Kenmore Dryers
Nu merge
Ce inseamna "nu merge" ?
Nu porneste ? nu porneste Windows-ul? Se restatteaza?
Mar 02, 2011 | Toshiba Satellite Pro L300 Notebook
Monitorul nu porneste la alimentarea la retea 220v care e problema
Please can you kindly give details of the problem with your monitor in English? Doing this will help me to suggest a solution to the problem.
I would appreciate if you can translate the problem in English for me to give advice.
Take care.
Jul 02, 2010 | Dell E176FP 17" LCD Monitor
Am instalat LG GH22NS40 in bios il vede dar nu
Verifica alimentarea, schimba priza SATA, asigurate ca e in prima sau a doua (celelalte doua sint cu probleme de driver) . Daca totul e in regula ti-a aparut in My Computer.
Pune un disc in el si incearca sa il deschizi in Explorer - daca nu e acolo (unitatea apare ca goala) sau dicul apare ca e gol atunci LG-ul e defect. Ca sa fi sigur de asta incearcal in alt pc.
Mar 17, 2010 | Soyo KT600 Dragon Plus Motherboard
NU SE MAI INCARCA SI NU STIU CE SA MAI FAK...NICI MACAR NU SE PORNESTE!
una,trebuie sa lasi mai mult in priza daca l-ai descarcat complet,trebuie sa verifici daca este conectat correct si lasa-l sa se incarce in manual scrie ca are o autonomie de 19 ore ar trebui ca macar dupa 17 ore sa il pui la incarcat oricum daca e nou trebuie sa incarci 16 ore de 3 ori pentru a formata acumulatoul.
Dec 01, 2009 | Nintendo DS Lite Console
MSI Wind UmNotebook Logo
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
