Question about Refrigerators
Ge monogram not cooling
42" side by side, built in, with compressor on top has stopped cooling below 45 degrees in both compartments. I took it offline for six hours, no change. Compressor and fans are working. It is as if it went into a defrost cycle and won't come out. Is it the electronic board? The freezer temp reads "0"the fridge temp reads "45". It feels like "45" in both.:0/ Very expensive units should be better than this!
    Top Expert:
  • Refrigerators Master
  • 75,797 Answers
You can fool with this and loose all your food to spoilage or get a service tech out to fix it or just replace it.
Posted on Jul 25, 2017
4 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Posted on Jan 21, 2009
VtToolMan
  • 704 Answers
SOURCE: 42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Posted on Jul 13, 2009
milten1
  • 1304 Answers
SOURCE: freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Posted on Oct 14, 2009
Testimonial: "it seems that even if I set the control to the coldest is dosen't affect the temps range"
Ge monogram zisw42emd, evap fan not coming on, Units been down a week, compressor seized,installed start kit. Compressor running 2.5 amps pressures 25/105 Replaced coil thermostats, evap fan not running.
that back pressures sound high to me and the hi side sound low may have a bad compressor not pumping right should run around 0 to 5 low 125 to 150 hi hope that helps
Oct 06, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Food is freezing on refrig side. although i set at 46 degrees(fresh food) will drop to 26 degrees and freeze food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram refrigerator does not cool. The fan on top was loose and not spinning. I fixed that, and it now spins properly, but he freezer and frig will not cool at all.
I need you to pull away from wall and remove cover over compressor and feel compressor for heat. If too hot to hold hand there or if warm or just cool. Tell me what you find. I would like to help you solve this if you like. Sea Breeze
Feb 21, 2010 | GE Monogram ZISS480NRSS 48" Built-In...
42" Built-in Monogram Refrigerator just lost power.
Check the Compressor starter. This is a black box on the top of the compressor. See if it is getting any power, also with a flash light you will be able to see if it is burnt it looks like a BIG fuse. If it is popped you will need to replace it then all will work ok after that
Jan 03, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Freezer is 0 degrees frige side only 40 degrees
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
May 18, 2009 | GE Monogram Side by Side Refrigerator
Vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
May 14, 2009 | GE Monogram Refrigerator Built-In...
Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Apr 08, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
