Question about Troy Garden
Troy bilt zero turn
I was using the mower the other day and cut it off to clean it before storing for the winter. when I was ready to put back in building the mower would not crank. I have checked all that i know to check. parking brake is on, levers are in neutral, blades are disengaged, battery is fully charged. It does nothing, motor does not turn. I have checked fuses also.
  • 1 more comment
  • AL Turcotte May 11, 2010
    Hi, has your problem been solve yet? please respond
  • Loringh
    Loringh May 11, 2010
    What was involved in the cleaning process.
  • ricardo r Oct 06, 2011
    i do have the same problem ... turns but wont crank . checked every thing but nothing
I have a zero turn Troy Built, It runs but the blades aren't engaging, I pull and push the pto button but nothing happens.
Posted on Aug 03, 2009
  • 36 Answers
Hi please check all the wiring connections as you must have disconected the power soarce feeding the key switch to the starter.
Start around the engine then the battery, check the seat switch , brake/ clutch pedal , & the mower deck switches .
One wire is just disconnected or the connection is broken so check all connections by unconecting & reconnecting them as it may even be a corroded wire that has been disturbed when being cleaned.
Posted on Dec 11, 2008
How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
At top right click on owner center and follow directions.
Mustang 50 XP Zero Turn Riding Lawn Mower
Sep 11, 2014 | Garden
Troy Bilt Mustang XP mower belt diagram
Aug 27, 2014 | Troy Garden
Troy bilt zero turn mower runs but does not move
Make sure the gears are engaged. There are 2 metal hooks on the rear of the mower, 1 on each side, if they are pulled out the mower is out of gear, make sure to slide them over so they retract back into the mower. If not the problem, sounds like either broken drive belts or the transmission isn't working properly.
Jul 02, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Mower: Troy Bilt 42 Mustang Zero-turn mower: The
Hello Donna,
I would remove the battery and have it tested at a local parts store. It sounds like the battery to me.
Sep 08, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
Troy Bilt zero turn Mustang Xp 50" deck height. My
raise the back as high as you like but unless you raise the front as well it will still cut short. If you want it higher and there appears there is no adjustment left you may have to re thread the adjusting screws to shorter dimensions or if it is on levers you may have to drill new holes further up the bars.
Jun 02, 2013 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
How much oil goes in my Troy Bilt Mustang RZT 50"
at least one quart up to 2 quarts
May 23, 2012 | Garden
I have a Troy Bilt 175 HP 500cc 7 speed riding mower. I just bought a new battery, and it still won't crank. It'll turn over like it wants to, but nothing. I put new gas with the old gas from last season...
If you didn't put fuel stabilizer in gas before letting the mower setup all winter, your gas has gunked up your carb.
You can verify this by removing the air filter and spraying starter fluid in the carb. If it cranks with the starter fluid, the carb is dirty.
Pull the carb and clean it out
Dec 08, 2017 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
679 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
