Question about JVC HD-52G786 52" Rear Projection HDTV
Spot on JVC hd-ila screen
I have light gray spots on the screen of my projection set. They can only be seen when the image is light. On darker background they cannot be seen. I have had three of these for some time and now a slightly darker one has shown up. They are always in the same place on the screen.
  • 1 more comment
  • rcpowley Nov 21, 2008
    JVC P61R1U
  • VFRLuke Apr 05, 2009
    I have the same thing going on in my HD-52g886. please advise if you've figured out what caused it
  • daloop02 May 24, 2009
    I have the same problem...how exactly can you clean the inside of the screen???
  • 320 Answers
There are several things that could be causing this. Dust or foreign matter on the inside of the screen, dust or foreign matter on the reflecting mirror or dust in the optical block or light engine. The first two can be fixed by you if you can gain access to the interior. The third will require a technician. If you have had your question answered, please be sure to rate the solution. Thanks!
Posted on Oct 31, 2008
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
Where is the projection lamp located in the jvc HD-70GC78?
hi there, I'm sure you can find it at the back casing fronting the screen. It has this box casing and you can see a glass prism. I also insert an image of JVC lamp. hope this help, please rate and vote
Mar 20, 2011 | JVC HD-70GC78 D-ILA TV
MY JVC52Z575 (D-ILA) HAS A REVERSED BLUE IMAGE OF ANY YELLOW IMAGE
I have the same blue shadow with reverse image on my JVC HD-52Z575 Did you see what the problem on yours finally was?
Feb 20, 2011 | JVC HD-52Z575 52" Rear Projection...
Feather like shadows on bottom of the screen JVC HD-61G887
This is convergence problems at it worse.U must have soldering tools,solders and know how to do soldering to solved convergence problems.Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
May 16, 2010 | JVC AV-56WP30 56" Rear Projection...
I have a 56" JVC rear projections HD ILA tv.
Turn tv off and unplug it. Take the access door off either side of the tv. Use a dust cleaning tool like a swiffer with an extension (or make one). Clean off lens (most likely the problem). I have the same thing that happens to my JVC 61". You can use a vacuum with extension if your VERY careful.
May 07, 2009 | JVC Televison & Video
JVC HD-61Z786 Projection TV: Problem: There is a light/dim spot on the tv screen. Thinking it was the lamp, I replaced the lamp and the light/dim spot is still there. Any ideas on the problem?
There is either dust on the lens or there is a problem deep within the light engine. This is a some-what common problem with these sets. The light engine is very expensive; not economical to repair.
Mar 30, 2009 | JVC HD-61Z786 61" Rear Projection HDTV
LG RU-44SZ51D 44 in - Gray Spots being projected
First trying cleaning off dirt /dust if after you do this and you still see spots then you could have a bad color wheel or bad light engine.
Jan 11, 2009 | LG RU-52SZ51D 52" Rear Projection...
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
455 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
