Question about GE Dryers
Wiring diagram for GE AUTO CLOTHES DRYER MOTOR. 5KH 26GJ116T. 572D676G003. MODEL # DVLR223EEOWW
hotuna
  • 288 Answers
SOURCE: Ge Commercial Coin-Op Dryer.
When you replaced the motor, did you replace the relay? It sounds like you have done everything reasonable. I would try bypassing the coin operation part and see if that changes anything. Go back to the motor relay. It may be incorrect application. the part guys only know what the computer tells them. it may need a different one. I am assuming that when the unit shuts off you checked for power from the timer to the next place, according to the diagram.
Posted on Mar 13, 2008
Testimonial: "Ended up selling all of our commercial washer/dryers and going with a rental company. Best all around for our cost, man hours and headaches."
  • 1073 Answers
SOURCE: Clothes Dryer Start Switch
part number is we4x782
Posted on Apr 12, 2008
  • 848 Answers
SOURCE: A/C fan motor burnt; I replaced it, and it will not keep runing very long.
It sounds like you'll probably need a capacitor .......
Posted on Jul 22, 2008
SearsTechToo
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
dragonsthatk
  • 547 Answers
SOURCE: need schematic for replacement motor GE dryer model DDE6350GALWH
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
Pushed start switch and making huming noise and won't start ge gas clothes dryer model dvlr223gg8ww
In most cases the motor is seized or something is preventing it from spinning (seized drum wheel for example).
Feb 10, 2015 | GE Dryers
Replacing ge dryer motor need wiring diagram
Need model number to provide wiring diagram
Dec 19, 2013 | GE Dryers
Dryer heats and then shuts off
know that it can be very frustrating to have issues with your dryer. If you have to wait for it to cool down before it will start again, this is an indication of the motor overheating and shutting off on the motor thermal overload. This can be caused by the motor being covered in lint or a low voltage supply to the motor. Check and clean the motor of lint and see if it runs normally.
Oct 14, 2012 | GE Dryers
Ge manuel for dryer model number DVLR223EEOWW
my ge dryer working but the clothes is wet and dryer is stoped wieh in 7 miniute
Aug 14, 2012 | General Electric Clothes Dryer Knob -...
My ge dryer dvlr223eeoww is making a loud noise when you turn it on it will work fine for a few minutes if a lot of clothes are in it then after a few minutes it sounds like it is going to fall apart.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 04, 2011 | Dryers
My ge automatic dryer model ddp 1275 c willnt
Sounds like motor trying to start. Simplest answer is article of clothing caught in the blower wheel and thus keeping motor from turning. Second is motor switch mounted to motor is bad. Not all dryers replace motor switch separately from the motor. Third, is the motor which contains a new centrifugal start switch with it.
Aug 19, 2009 | GE Dryers
Dryer Shuts off with full load
ok so it runs for the full time set when on timed dry. auto from optimum or less dry runs quickly, correct?
Auto runs on yours by advancing the timer whenever the thermostat is satisfied with the temp coming out. This has a wire that runs from the heater to a resister mounted in the console area then to the timer providing the power to run the timer motor. Most commonly the heater is the cause. GE dryers have 2 elements side by side that operate indepenently but if one goes out the unit will still heat but the circuit for auto is like the heater is off advancing the timer.
the heater is located behind the drum on the wall. first measure the resistance on the resister, i believe 1.4 k ohms see diagram behind it.
to get to heater, remove 2 phillips screws inside door opening top holding top down. then lift top and slide to left if plastic console. to unhook from console. remove 2 screws holding front to cabinet, disconnect wires at bottom left on panel. reach inside on bottom (2 hands may be necessary) pull tensioner arm to right and hook on motor side, it will stay there till pushed. you will get red grease on you. Now you can pull the drum straight out, its a tight fit up front you can remove a side screw to help. you now have an excellent view of the heater. any breaks in either coil?
May 03, 2009 | GE DBXR463EDWW Electric Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
GE Dryer Will not start
possible door switch broke when uou shut it back also ck wiring diagram under console for thermal fuse in motor circuit
Jul 24, 2008 | Dryers
Dryers Logo
217 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
