Question about Home
Tank wont refill/how to fix
my tank wont refill after flushing /what to do to fix?
the brand is American Standard.
  • 374 Answers
JC most commonly the ball **** will hang up on the side of the tank. Take the lid off and ensure that it is in the down position. If it is not bend the rodso the ball move away from the side of the tank. If the toilet is running continously and the tank won't fill you will need to either replace the flapper valve which is in the bottom center of the tank or adjust the chain on the flapper and handle to allow the valve to open momentarily and close once the water level reaches it and drains out the hole.If all of the above did not resolve the issue you will need to replace the ballcock valve which is the piece the water supply attaches to underneath the tank on the handle side and protrudes through the tank and has the ballcock rod attached to it. The best replacement is a Fluidmaster as they are very easy to self install and easy to adjust the water level in the tank. I hope this assists you and thanks for using Fix Ya. If I can be of further assistance please let me know.
Jim
Posted on Nov 10, 2008
Delay on tank refill after flush for American standard toilet
The washer is sticky inside the valve. Depending on the type, you either replace the washer or diaphragm, or completely replace the inlet valve.
Easy job, just Google or YouTube.
American standard toilet Google Search
Dec 05, 2016 | Cameras
What causes a loud gurgle after flush?
If the flapper does not seat correctly and completely, refill water flows into the bowl and causes a "false flush" and the loud gurgle. You can demonstrate this by holding the flush handle depressed after a normal flush. Also, there may not be sufficient slack in the flapper chain to allow it to seat correctly.
If the flush valves were installed exactly according to the instructions, they should work perfectly and can be excluded as a source of the problem.
Jan 23, 2016 | Home
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
Sep 20, 2013 | American Standard 2004.014 - Champion...
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Nov 21, 2010 | American Standard Cadet 3 Right Height...
I bought a toilet from homedepot in toronto 6 months ago. from yesterday, it keeps to refill the tank like every 10 seconds. but i can not see where the water leaks
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
May 12, 2010 | American Standard 2860.334 Enfield Two...
Problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
May 08, 2010 | American Standard 2004.014 - Champion...
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Toilet tank is refilling slowly.
Hi AaronYC,
I'm Harvey the Master Plumbe.
Your problem is: Installed a new American Standard Cadet 3 toilet bowl and tank at home. When you turn the water supply on, the tank refills normally and stops normally. After you flush, the refill is very slow. When it refills normally the water comes out from the bottom of the pipe (i.e. the pipe that houses the float cup) and when it is refilling slowly, it comes from the top of the pipe. Sometimes (but not always), you can shut the water supply off and when you turn it back on, the flow of water goes from slow to fast instantly - but you haven't been able to recreate this consistently.
These are the facts. American Standard has been keeping costs down by out sourceing. Their toilets are now built in third world countries and parts are made cheap. They're all doing it. Quality control is pretty good but your toilet came with a bad "ballcock". That's the refill part on the left. Because it's new, if you take the ball **** back to place of purchase they should give you new. If not, they cost less than $ 10.00 and easy to replace.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | American Standard Home
Home Logo
449 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
