Question about Sony Cyber-Shot DSC-W5 Digital Camera
Flash doesn't work as it should
About 6 months after I bought it my W5 the flash started to show up problems. Pictures taken winth flash either come up to bright or to dark. As far as I have noticed, the first short flash used by the camera to estimate the optimal flash level comes up totally ou of the time, confusing the sensor. With pictures without flash the camera works fine. Is it a problem in the flash controller (if such thing even exists)? Can I fiz it myself?
    Sergeant:
    Champion:
  • 326 Answers
Hello, in order to repair your camera the IC851 is to be replaced. This integrated circuit is used for flash control. Please do not try to fix it yourself. Contact your nearest Authorized Sony Service. If you need more info please advice.
Posted on Apr 11, 2007
FUJIFILM FinePix S2500HD bought two months ago. Flash is now refusing to work. Please help!
Same problem with mine - bought in February, (now May!) flash doesn't fire. Indicator light flashes orange which the manual says means "flash charging" but still no response despite waiting for that to complete.
Hope this isn't a bug in this model... Fujifilm, where are you?
Nov 07, 2010 | FUJIFILM FinePix S2500HD / S2600HD Digital...
When I put the sd card in and then turn power on it ask to format. no matter if I input yes or no the camera then shuts off
i have this w5 camera for the last 3 years few months back an error appear named E;91: like that and sometimes a beep sond for few seconds also on flash mode i cant take pictures i solved that problem by initialise the settings.now that problem started i initialise and formatted also remove the memory stick and again initialise and formatted but the error continues.i can only take pictures without flash what can i do please give me ur valuable suggestions
Oct 12, 2009 | DXG Technology DXG-572V Digital Camera
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Shutter button fell off Sony Cyber-shot DsC-W5 Camera
I bought a "for parts" dscw50 off ebay & unscrewed the side panels; this allowed me to remove the whole top panel (entire silver piece) & exhange it with the one on my own camera which I had broken the shutter button off of. Works fine now.
Jun 23, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Black pictures when using flash
The black images with flash mean that the Iris mechanism in the lens is not working properly, and that needs a professional camera repair service.
Best regards,
Oct 19, 2008 | Canon PowerShot S2 IS Digital Camera
Canon SD 550 does not work when flash setting is ON
I have the same problem. Cannon customer support says it will fix this for $119 + 8 for shipping... or you can get a refurbished SD 800is for $140+10 for shipping with w/ a 6 month warranty... what a deal ;~)
Sep 04, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Flash doesn`t work!!
In warranty case however, in order to repair the above mentioned error you should replace the flash circuit board part number:A1166208A.Price for the spare part is 35 Euro (for my account). If you need more info please advice.
Mar 30, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Canon550 flash problem
having the same problem, although after about a year of having it. i've come to the conclusion that the flash itself is broken, if you shake the camera you'll hear something moving around (at least that's my case) and i'm supposing it's similar to a burnt light bulb kinda thing. so the solution would probably be to send the camera to canon itself or find someone who can replace the flash (and buy one as well). I can't do either because I live out of the US =(
Dec 10, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Sony Cyber-Shot DSC-W5 Digital Camera Logo
48 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
