Question about HP Office Equipment & Supplies
Hp p2055dn network connections disappear
Have network connection problems with several HP P2055dn printers. 1 is connected via a router and another via USB cable to a Windows 7 laptop. Each is part of a wrieless network with several laptops. Laptops that have been set up with the printer as a networked printer will suddenly lose the connection. After losing the connection these laptops can not find the printer again even though both the server laptop and the remote laptop reboot. Very frustrating and eventually only the server laptop can print. On another network with a XP server laptop and the HP P2055dn printer attached via USB we have not encountered any problems.
SOURCE: Printer eventually loses connection...
If I power off my HP printer, the DPR 1260 loses connectivity with the printer. I have to reinstall using the USB connection from the printer to the PC, then DON'T POWER DOWN THE PRINTER, & then move the USB to the server & reinstall. The printer will work as long as the power to the printer stays on.
Posted on Jan 21, 2008
  • 14 Answers
SOURCE: I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Posted on Oct 13, 2008
  • 47 Answers
SOURCE: Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Posted on Nov 27, 2008
SOURCE: HP Photosmart 2710 is not recognized over wireless connection
light it on fire
Posted on Dec 08, 2008
  • 84 Answers
SOURCE: Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Posted on Jun 02, 2009
Why isn't anything appearing in the control panel display of my HP Laserjet p2055dn?
try giving ping command to the ip of the printer
if you get a reply from the printer in the command prompt then the printer is properly connected to the network. for a precaution try to switch off the printer and if then too you get a reply there is conflict with the same ip.
if you get a proper reply from the ip try installing the driver once again
May 03, 2016 | HP LaserJet P2055d Printer
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
HP P2055DN LaserJet: I/O card not ready
Check your network connection. I got that message on my 2055dn. The problem turned out to be a defective ethernet switch where the printer cable hooked up to the network. A new switch fixed everything.
Oct 16, 2012 | HP P2055DN LaserJet Monochrome Printer
HP LASER JET P2055dn 10.000 SUPPLY MEMORY ERROR
I have an HP LaserJet P2055dn and I am getting a 10.000 supply memory error. I've checked HP's website and I am not finding anything related to this problem for my printer. What do I need to do?
Thanks,
Mike
Jul 17, 2012 | HP P2055DN LaserJet Monochrome Printer
I need to swap out the network card in an HP Laserjet P2055dn, and I can't figure out how to remove the side panel.
I believe that the P2055 has an imbedded jetdirect.
You would have to change the formatter.
That could run into some money.
Is it still under warranty? Let HP do it.
Oct 24, 2011 | HP P2055DN LaserJet Monochrome Printer
Model - HP Laserjet P2055dn. Issue - 49 Err 64003D5, Turn off and then on . Tried many times, keeps showing the same error after turning on. Change the network cable but no use
Had the same error. Turned out the pdf I wanted to print had an empty page. When I removed it, the error disappeared and I could print the document.
Mar 13, 2011 | HP P2055DN LaserJet Monochrome Printer
I had the same problem. The source of this problem, the USB printer port is broken, then I use network configuretion. The poblem is solve.
Dec 20, 2009 | HP P2055DN LaserJet Monochrome Printer
I have to install a hp p2055dn printer defining a IP address
go to menu button on the front panel of printer. then go to network setting . assigne there static ip with subnet mask and default gateway of you network.
Aug 22, 2009 | HP P2055DN LaserJet Monochrome Printer
220 people viewed this question
Seeker5211
Seeker5211
